Question about Frigidaire FEF355 Electric Kitchen Range
Frigidaire Electric Range Model FEF355ESB
I have a Frigidaire Electric Range Model FEF355ESB. When I push the bake button the oven will not heat. Neither the broiler element nor the bake element will come on. If I push the broil button the broil element will come on then. What could be causing this problem?
  • Frigidaire Master
  • 43,501 Answers
If your electricFrigidaire Electric Range Model FEF355ESB - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 14, 2010
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
316418305 broiler element and bake element will not heat
Good Afternoon Friend,
I see that you are having trouble with your Frigidaire range, model# FEF336BC, broiler and bake element not heating. I would give your range a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn your oven on and if the elements are still not heating, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 23, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
Frigidaire oven will not light
The control panel behind the knobs is the most likely problem.
The heating element rarely fails.
Apr 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Lower heating element in oven does not work
so this unit is electric? does the broiler work? if the answer is yes , the broiler does work...more than likely you need a bake element. Do you have a multimeter? you can also check to see if you have 240 volts going to the element when you turn it on if you have voltage your problem is 100 percent a bake element that has gone bad.
Dec 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My broiler and range work but my "bake" option will not produce any heat??? Please help!!!
If this is an electric range, it sounds like you have a bad bake element in the oven. The broiler and bake features each have their own heating element. Thats why the broiler still works. The following link explains how to replace a heating element in an electric range:
http://www.fixya.com/support/r469407-replacing_bake_or_broil_element_in
If the model range you have this question listed under is correct, the part number for a replacement element is WB44K5012. It lists for about $25 at pcappliancerepair.com.
If you have questions, or if the model number is not correct, please post back with your information so that I may be able to provide you with better assistance.. I hope you find this information helpful.
Oct 15, 2009 | Hotpoint RB757 Electric Kitchen Range
Oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
May 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FEF355 Electric Kitchen Range Logo
651 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
