Got an american spec peavey guitar amp pluged it in to a british power supply via a visitor adaptor (which complies with bs5766 ref no:1073) it went pop and smoke came out.
  • Rommel Cana
    Rommel Cana May 11, 2010
    hi
    scotia1565, Thanks in advance for choosing Fixya for assistance, I would like to clarify: 1 ) what went pop and smoke? Is it the adaptor or the guitar amp. Should you feel too DIY and feel you can work inside the unit , 2 ) I need to know what Model of Peavey Guitar Amp , you are using? 3) describe details ( Model , capacity ) about your adaptor Hope to receive response from you as soon as possible , so we can have a more possible solution for you. regards, palaboy
    Problem Solver:
  • 17 Answers
The adaptor is not designed to supply enough power for your amp.
Posted on May 19, 2010
Peavey 6505 plus buzz...even when all controls on zero and no guitar plugged in
Sounds like a bad power supply filter cap...the buzz you're hearing is the 60 cycles hum that filter caps reduce or (hopefully) eliminate altogether. It may also be related to the tubes but finding the bad one will require some work. Any friends have this same amp? If so, try swapping one tube at a time and see if you get lucky. If this amp is new take it back ASAP as it is a manufacturing defect.
Dec 27, 2013 | Peavey 6505+ 112 Combo Amp Combo
Peavey Problems
Check speaker impedance or disconnect speaker leads, then use a 9V battery to verify cone movement and if this test is ok, then go inside the amp, if there's no fuses blown check opamps supply voltage which should be -15V at pin-4 and +15V at pin-8, let me know your results to help improvement.
May 21, 2013 | Peavey Electronics Peavey Max 112 Bass...
Peaveyvypyr75willnotturnon
Check power supply fuse inside cabinet, if this is ok you may have good reasons to suspect that your power module got fried.
Mar 30, 2012 | Peavey Electronics Peavey Vypyr 75 -...
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
May 30, 2010 | Peavey Valveking Head
Peavey banit 65 guitar amp. When turned on it makes a loud almost feedback sound with out anything pluged into it.
A few things can cause it. Bad ground\bad power supply filter capacitor\bad low level op amp IC. You most likely have a bad power supply or trouble at your input jack. Good luck!
barneyluc
Oct 09, 2008 | Audio Players & Recorders
AC Adaptor
If there isn't a switch to select 110 or 220 it should be ok , i had a charger like this and it worked well on 220 altrought I had to plug it with crocodiles clips
Oct 13, 2007 | Uniden BC92XLT Handheld Scanner
 Grubhead
Grubhead
