I need the code to enter into my tivo remote to be able to turn on/off and volume up/down on the samsung blu-ray home theatre ht-bd1200
SOURCE: Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
If your television has RCA style audio/video output you can use an audio RCA cable (red & white connectors) and simply plug from the 'output' of your television into the auxilliary input on the back of the HT-BD2.
Then select AUX on the HT-BD2 remote, whenever you wish to listen to the television audio.
SOURCE: I have bouight a samsung home theatre system that
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
SOURCE: Have new Samsung 3D Blu Ray Home Theatre system
If you've find an answer to this, would you please post it here?
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1) From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
