On a new installation on AR-5516 sharp copier and i used developer 205 and Toner 021 and its showing F2 40
  • 328 Answers
When you install developer you must enter code 25-2 and wait for about 3 minutes to turn motor and DV unit and copier will scence ATC sensor ,then turn off and on .
Posted on Jun 08, 2010
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
Aug 21, 2011 | Sharp AR-5320 Black and White Copier
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
I' ve a problem with copier ar 5516. i need information about using of developer. where i must to put the developer? the toner AR-021FT IS COMPATIBLE WITH THIS COPIER?
yes ar021FT toner compatible for your 5516. when replacing the developer:1) pull out the toner cartridge,2) pull out developing unit with 1 screw (blue),3) in developing unit remove 2 screws (blue) to open its top cover,4) drain d unit and replesnish with new developer. do procedure 4 to 1 to return. Good luck.
May 22, 2011 | Sharp AR-5320 Black and White Copier
F2 40 error code on Sharp 5516s copier
you must use ar-202 developer.205sd used for 5516 or 5520
May 23, 2010 | Sharp AR-5320 Black and White Copier
AR 5516S SHARP COPIER IS SHOWING F2 4O FAULT CODE DURRING INSTALATION. WHAT COULD BE THE CAUSE. PLEASE.
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Mar 12, 2010 | Sharp AR-5320 Black and White Copier
My sharp copier AR-205 will not copy and the letter CH or showing up
Install the developer unit and toner cartridge properly and close the copier side covers well ie the front and the right covers.
Nov 24, 2009 | Sharp AR-M205 Copier
Sharp digital 5516 drum life indicator along with a man flashing. Also any compatible toner available for sharp 5516.
Try a reset first (Press #, interupt,c,interupt, then 14 start), If it pesist, Check the drum for injury lines, the developer for inpurity and clean the toner catradge proper, the close all machine doors. Good luck.
Apr 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
293 people viewed this question
jasbo
jasbo
