Question about Brother HL 1440 Laser Printer
Does this printer copy? It has a tray in the front to insert paper to be copied
    President:
  • 405 Answers
No this printer doesnt photocopy, The tray in front to insert paper is for thicker paper or enveloppes or labels.
Posted on May 08, 2010
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
I am trying to just make a copy and the printer is pulling paper from the photo tray, I'm not sure why, I'm pressing the copy button.
Go to front panel of the printer
press set up then got to paper tray settings
you can choose adf tray or the main tray for pulling out papers
it may help you a bit
try also to power cycle the printer
Hope my idea will help you a bit just give it a try
Thanks
Mar 27, 2011 | HP Photosmart C5580 All-In-One InkJet...
DCP 8065DN
please print option paper source setup mp tray and setup page size then solve your problem
mp tray is copier front side open it and insert paper or print source lower casset
i pray you wiil success
Sep 03, 2009 | Brother DCP-8065DN Black and White Copier
How do i put paper in the bypass feed of the OKI printer? I can't find the bypass tray or how it put in a thicker paper.
The by pass tray is located in the right side on copier machine.Insert the paper select the tray and made a copy.
Aug 19, 2009 | Ricoh Aficio 250 Copier
How do I copy a document on a lexmark x 1185 printer scanner copier
Turn the documents printed page away from you. (Document facing you, turn it around so that the print is on the backside)
Insert it in the top paper feed tray. Align the left side of the document page, with the alignment bar on the left side of the top paper feed tray. (Put the left side of the paper against the plastic bar on the left side of the paper tray)
Computer running, Windows loaded. Go to Start>Hover your mouse cursor on All Programs>Lexmark>Lexmark Printer
Click on the Copy function, and go to the Properties window to set how many copies you want, (Default setting is 1), what size paper you're using, and so on.
Jul 13, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Brother printer mfc-7420 will not print
Manual feed is a by-pass tray (not the paper tray,)
in this particular model it looks like one of hte slots in the front. put a paper in and see if it grabs it.
you should be able to cancel out the job by pushing stop/cancel?
1-check the tray to make sure the paper size is correct
2-make sure it is set for tray not bypass
Jul 30, 2008 | Office Equipment & Supplies
Copy Orientation
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
Jun 10, 2008 | Canon imageRUNNER 5020 Copier
Brother HL 1440 Laser Printer Logo
54 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
