Question about Oregon Scientific Electric PTO Clutch for Exmark and Warner
White LT-12 lawn tractor 139-656-190 Mower deck on right side is out of alinement. Rear tire rubs on deck when lowerd. How do I ajust the deck?
I have exact same problem with my 1989 built LT-12 White tractor ! I Discovered that the Right side connecting Link #14802A,that connects the lift handle shaft #17154A with the Stabalizer bar #16465A, was broken where it connects with the Deck Lift handle shaft.
Posted on Sep 09, 2010
Change rear tire on john deere lawn tractor lt-150
i guess the wheels are stuck you will damage the wheels and axle trying to get them off just pop the beads and change it right on the mower
Apr 16, 2012 | John Deere Garden
I purchased a used Craftsman LT 1000 17 hp 42"
I've had to do this at least 5 times. If you look under the body, there are two supports that carry the mower deck and lift and lower it. Each of these has a nut that holds up the deck and the nut is on a stud that goes up and down when you raise or lower the lever. Put the deck in the middle of it's range, around #3, make sure the key is off, move your blades so they are on the right and left edge of the deck.
Get yourself a device to measure blade to ground height, I have a block of wood that is 3 inches long. Make sure your floor or ground is level and tires are properly pumped up. Then raise or lower the adjustment nuts until both sides are equal height.
Gary
Jun 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Install mower belt
Lift the front of the tractor about 3 feet off the ground& remove the right side rear mower hanger to give you clearance to do the job. Make sure you get the belt on the pulleys and not rubbing a blade brake arm or an idler pulley keeper or the new belt will burn off in about 10 minutes.
Oct 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I want to repair one of the rear tires. How do I disassemble?
Hard rubber or plastic cap in center to be gently pried off, this will expose a C clip holding the wheel onto a splined shaft. Jack the mower frame up until the tire is off the ground. Remove C clip and then the wheel, being careful keep it, the washers, and the key in order. If you lose the key, which will fall out when you pull the wheel off, axle will not spin the wheel when you put it back together. Note tire can accidentally be put on backwards, so make sure you do not do that or you will rub a groove right through the tire. Mower tires cost more than car tires. Most tire shops can also fix large mower tires.
Jul 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The blades are cutting unevenly
I know this will sound a little crazy, but check the air pressure in you tires. My neighbor had the same problem. The tires looked okay until he sat on the mower. One of the rear tires was low which caused the mower to sit lower on one side. Next check the linkages on the deck to make sure they are hooked up and haven't fell off.
Apr 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Huskee LT 42 Lawn Tractor's mower blades drag on the left side cutting into the dirt.
check blade to see if it is bent or perhaps the blade spindle is bent are the tires properly inflated on a flat surface ceck to see if the deck is level good luck
Sep 07, 2009 | Mtd Garden
Rear brake is sticking, how do I fix it
take the passanger side rear tire off & the brake caliper should be looking right at you looosen & take off caliper & there are 2 little dow pins in there that get frozen tap out with hammer drill holes alittle bit bigger add alille grease or assembly lube to it & reassemble
Jul 17, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Oregon Scientific Electric PTO Clutch for Exmark and Warner Logo
703 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
