Question about Karcher Garden
Hi Bought karcher k5.80 some time ago It didnt work well and I put it away however got it out again its blasts then trickles water on for couple of seconds the off again. What if anything can I do?
I got the same problem as msellar1. Anyone got any ideas to resolve??? medcalf.chris@virgin.net.
Thanks.
Basically, turning the spray nozzle to reduce the pressure works - but this is next to useless for cleaning anything. I fixed the leaky tap in case air was getting into the system but no. It's been like it since day 1, on and off, but now more stop & start than ever! Maybe thats why it was reduced to I think £150 from £275???
Posted on Jun 12, 2010
Can i get back money if i accideltaly ordered 3 yoyos a couple days ago?
sadly we have no idea here on FIXYA only you and the place you ordered them from can fix your mistake .
Oct 09, 2016 | YoyoJam at Yoyoplay YoyoJam Fiesta XX...
I have a karcher hd605 and it doesnt power up anymore, It wasnt used for a long time because it didnt have a gun but when i picked one up it worked a couple of times then no power Please help!!
power cord. or power supply inside . sometime it has to be one of their gun. not from another company. reset the power cord. if not its inside
May 14, 2015 | Karcher Garden
Water does not flow
Sounds like air in the line.....the filter may be cracked/damaged, or not quite seated...?
since you've tried 2 new ones....I'm gonna bet they are not quite the correct ones for your fridge.
Sep 07, 2012 | GE GSHF5KGXBB (254 cu ft) Side by Side...
HI I was blast died on the highway going about 65. After a couple minutes it started. I got off the highway and it died again. I put some new gas in it ( it was in storage for the winter) and was able to...
Dunno - water in the gas or bad gas will do it every time. Drain the gas out of the tank and empty the carb. refill with fresh and run it. Some more info about what happened would be good too.
May 29, 2011 | 2004 Buell Blast
My hubby bought me a nintendo ds and a couple of games about 2 years ago, all worked fine, i put it away and didnt play with it for ages, started playing with it again recently it works fine with my...
have you tried updating the firmware on the DS? It maybe because of that , that it wont play newer games? You will need to connect the DS via wifi to your home network the same way your laptop etc connects to it and then go into the DS settings menu and choose system update. Make sure the DS is fully charged and connected to a mains charger BEFORE updating. See if that solves your problem for you
Mar 20, 2011 | Nintendo DS Console
Car won't start after battery was cleaned.
what do mean the battery was cleaned ? was the fluids inside removed ?
or was the terminals (where the cables connect) cleaned due to some whitish build up ?
If the fluids inside were cleaned you can try (and this will probably not work). remove the battery from the car.
open the battery (the caps where the water goes in). remove the fluid inside (be careful it may be sulfuric acid) then rinse out the battery a couple of times with hot water.
leave battery in sun with caps off to dry out completely.
fill the battery with battery acid.
Put the battery on a trickle battery charger for 24 hours or until charger indicates full charge.
Reinsert into car and connect the terminals.
See if it worked.
If it didnt -> replace the battery
If the terminal were simply cleaned, lossen the terminals with the correct spanner, pour some hot water over the terminals to wash away any residues, then while the terminal are still wet fasten the terminals once again.
Remember that should the fluid inside your battery gets low (should be checked regularly) fill it with battery water (distilled water) only.
Oct 11, 2010 | 1997 Toyota Camry
Water has been trickling to the drain for at least a couple of hours now, maybe longer. I just noticed it this morning. It's currently in regular run mode and not in regen mode. I put the valve to...
There is a problem with the main piston/sealpack assembly and it needs to be replaced. You can get this kit at Culligan and replace it yourself, if you are handy, it takes about 20 minutes. Replace the refill piston at the same time. Or have Culligan do it.
RJ
May 15, 2010 | Culligan Sediment Water Filter
Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Apr 27, 2009 | Moen & One Handle Tub & Shower Faucet
Garden Logo
223 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
