Question about Equator 23 in. WB72 / BB72 Built-in Dishwasher
No water running through and machine not cycling off
This machine is in a business office. I am the office manager and last week I was on business travel. When I returned on Monday, I thought someone kept turning the machine on in the a.m. Today, I noticed the machine still running from when it was set last nigh - but no water was running through and it didn't turn off when I moved the dial to an off position. I had to open the door, push the button off for it to turn off.
3 Suggested Answers
SOURCE: The machine will fill with water and run through
Have exactly the same problem. At first thought it was broken drain pipe--as I found broken drain pipe searching for a fix for this--coincidence? Anyway, drain pipe fixed, and unit still will not enter spin mode. When unit gets to spin mode, there's an audible click (solenoid), and the unit will not spin or drain the water.
All else is working fine.
What part should be replaced?
Posted on Nov 29, 2009
  • 24 Answers
SOURCE: 3612 CEE is washing OK,
I'm having the same problem.
What was the solution to your problem?
Posted on Mar 22, 2011
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
Can Microsoft Picture Manager v. 11.0 that was working great in Windows XP sp3 be configured to work in Windows 7?
Get to Properties for Picture Manager (e.g. if you have a desktop icon you can right clck and Properties will be the last choice on list) and the third tab should be compatability.
Click on the top most box to Run ... and it will enable prior Windows versioning. Pick XP SP3 (sixth choice). The pick OK or Apply.
There is a Help Me dialog that you can pick that will assist with settings if the above basic fix is not sufficient.
Oct 20, 2014 | Microsoft office professional plus 2013
Dishwasher won't drain. (Kenmore 3380957Rev A) It's been not draining that well for a couple of months, but then a couple of weeks ago, it just won't let the last inch of water out. --I can't see in...
The problem could be the pump, the drain hose or the timer. It will not drain if left to sit. The thing to try first is to put a cup of white vinegar in the machine and let it wash. This may remove sludge or scale blocking the strainer. 2nd take the hose loose at the sink drain and see if it is half clogged with grease or food. Check the hose and the nipple. Last, if it does not work take the bottom off the dishwasher. 4 screws and a plate. look for the pump and see if the hoses are clear. Sears will sell you a manual to repair and test this machine at its Parts Central on line
Jun 24, 2010 | Dishwashers
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Equator 23 in. WB72 / BB72 Built-in Dishwasher Logo
Top Equator Dishwashers Experts
Paul Carew
Jaye t rock
Are you an Equator Dishwasher Expert? Answer questions, earn points and help others
