FixYa.com
Tags:
Washing Machines
Generic problem for all Washing Machines
Door locked
posted by izor on Mar 27, 2008
Door is locked after wash is ready. Won't open.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 15, 2008
FixYa! (100)
sol1
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
we have a maytag neptune front loader and the door would not open and it kept showing a DO error. This is the way to get your door open. Under the bleach and softener dispenser there is a green plastic cord. Pull on it and it will open your door.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 27, 2008
Not Rated (0)
Mike1901
Rank:Guru Guru
Rating: 88%, 44 votes
Probably a faulty sensor, you will need to get it checked out and the sensor replaced.
This Problem Also Relates To: GE WSXH208A Front Load Washer GE Energy Star WCVH6260F Front Load Washer Bosch Classixx WFC 2465 Front Load Washer Bosch Logixx WFT 2806 Front Load All-in-One Washer / Dryer Bosch Axxis+ WFR 2460 Front Load Washer Bosch Classixx WFL 2462 Front Load Washer Bosch 3.81 cu ft Nexxt 500 Plus Series Washer - WFMC530 1UC / SUC / CUC / WFMC530CUC - Champagne Du
Can you Help with these Washing Machines problems?
Kenmore 44072 Front Load Washer
Only completes one wash - have...
Kenmore Front Loader washer is... Answer This...
Washing Machines
Maytag Atlantis motor burned up
Maytag Atlantis motor burned up... Answer This...
Washing Machines
hot point aquarius washing...
hot point aquarius washing... Answer This...
Washing Machines
Waching M Beko 756 s
beko Wma 756 s NO water... Answer This...
Washing Machines
model mex731cas3 - cycle stuck
model mex731cas3 - cycle stuck Answer This...
Repair Service
Find Washing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
