Question about Admiral AAV7000A
My washer machine does not hold the water keeps draining
The washer machine keeps filling but never holds the water
  • Admiral Master
  • 43,501 Answers
Here is a tip that I wrote about the problem you are having with your washing machine...
Water will not stay in Washing Machine
http://www.fixya.com/support/r4696322-water_will_not_stay_in_washing_machine
heatman101
Posted on May 07, 2010
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
My whirlpool won't fill up all the way. It just keeps pouring water and draining.
The drain hose MUST be routed higher than the console, or it will continue to drain. There must be a vacuum break (not tightly sealed will work) at the intersection between the hose and the drain pipe.
There is actually no drain valve that keeps the water in, but rather the physics of routing the drain hose HIGHER than the console of the machine. At minimum higher than the machine's top deck.
Nov 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
It won't hold water just keeps draining even while its filling. I bought a frigidaire stacked washer dryer and i just hooked it up today everything works great except when i turn it on it will work normal...
help is on it's way ... the drain hose needs to be 36 in high. . if it's too low it will drain and fill all day . you can use a drain ext. or longer hose if needed. if this does not correct problem / were still here . mm
Nov 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Jan 06, 2009 | Maytag Legacy Series Top Load Washer
My kenmoe washer starts filling up with water but won't fill up. Water is just keeps running through but won't hold the water.
You drain hose must be higher than the tub. you can solve this with a standpipe or a siphon break kit.
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
Water keeps running
missmelissa, sounds like you are siphoning. Lift the drain hose from the drain and see if it fills then. You need to have a air gap on the drain so you don't get the siphoning affect. Catriver..post back.
Feb 23, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Admiral AAV7000A Logo
313 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
