Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
My print copy is unclear, even though the ink level is full and I cleaned the heads
    Sergeant:
  • 144 Answers
There are two possibility
1. Re - install the printing software which is available in the cd given to you at the time of purchase
2. Replace a new cartridge
Your problem will be solved or else call technician.
Thank you
Posted on May 08, 2010
I installed a new black ink cartridge and now it won't print black even though it shows its full on in levels
If your black cartridge was empty for any length of time before you replaced it, even if it was still installed in the printer, chances are that the black print head nozzle has dried ink in it. Cleaning may or may not resolve the problem, but cleaning also uses obscene amounts of ink. Epson printers are notorious for clogs since they have some of the smallest print head nozzle sizes (thus their high dpi resolution).
There are some Youtube videos that suggest ways to clean severely clogged Epson print heads. I cannot vouch for them as I have never tried them, but you can view them and decide for yourself.
Feb 04, 2016 | Epson WorkForce WF-3620 Wireless Color...
I have an Epson RX680 the black and yellow ink are not printing after trying several print head cleanings and even replacing the cartridges (even though they were better then half full)
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 15, 2012 | Epson Stylus Photo RX680 Printer
I have a canon pixma 780. I hardly ever use colour yet the colour cartridges keep running out.
Every time you turn on your printer, it goes through a print head cleaning routine and the print head nozzles flush all the inks into the cleaning pads. This is why the inks are levels are dropping even though you have not printed anything.
Nov 02, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I cannot get the yellow colour to print either as a test print or full copies. I have cleaned the heads, checked ink levels and even replaced the yellow cartridge again but with no success.
Try the following steps.
1) remove the ink cartride and ckeck for damages
2) remove the ink cartridge and replace it securly.
Else the ink cartridge is faulty.
Apr 20, 2011 | Epson C64 InkJet Printer
Epson SX600FW - this will not print black even-though the cartridge is genuine and full. It will print the document in any other colour than black
You might need a reset as the B&W cartidge has not been detected. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 06, 2011 | Epson Printer
The printer wont print the black i checked all ink levels but did notice that i usually gey a small screen telling me how full the levels are but i get no reading. i've changed the black ink and still...
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Nov 30, 2010 | Brother MFC255CW All-in-One InkJet Printer
Black ink won't print even though the cartridge is
It could be you just have a bad cartridge, If it's new, take it back and get a new one to make sure it's not the cartridge. If you get the new one and it still doesn't print black, then you have a bad print head. Meaning it would need to go to a service dealer to replace or repair the print head.
Thanks Mark
May 14, 2010 | Brother DCP585cw AllInOne InkJet Printer
Prints Blank Pages...even though ink is full.
problem is likely to be the print head, the ink can dry up inside the print head and block fresh ink from flowing.
you can get print head cleaning solution from ebay, which sometimes works, or else go here to get your replacement print head
www.kodak.com/gb/en/consumer/products/printing-supplies/printhead.../default.htm
the one i have is a clip in clip out part
May 03, 2017 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
62 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
