YES !!
Make sure you have a fully charged battery before downloading ur maps.... the map download my take up to an hour or so to upload...
once you charge your battery this is what you need to do:
Using the USB cable connect your gps to computer.... ( if you didnt get a usb cable you could use most camera usb cables they connect the same way )
your computer will detect new hardware, a autoplay box will pop up, you can minimise it
next
go to
www.MyGarmin.com
it too will detect your new unit and have you Register your GPS.... its free
Garmin will have you download WebUpDater utility this is what you need to transferr and open Maps
follow the easy directions your not long from completion..
********** where you first setup your gps this wil be called your
SECURITY LOCATION..... if you ever lock your unit you need a Pin Number to unlock it..... if you forget or lose your Pin Number you must return to the
SECURITY LOCATION where you set up to unlock your GPS
