Question about Garmin nuvi 200W GPS Receiver
No display on the unit even when plugged in the car charger.
I worked the switch back and forth with no results. The unit hasn't been used in about a month. The charger led does so power.
    President:
  • 1,851 Answers
You need to charge over night from the wall unit -
Posted on May 07, 2010
I cannot get my Garmin nuvi 255w to turn on even when plugged into it's power source - the car charger or the indoor plug in charger. There is no display, just a black screen.
Try a master reset. Hold the power switch to the left and hold for 10 seconds and release. You may also have a bad USB charging port. A common problem with units with USB only connectors.
http://www.sharc.net/gps_charger_repair.htm
Aug 20, 2013 | Garmin Nuvi 255 GPS Receiver
My Garmin Nuvi 250 w gets stuck on the screen showing a picture connecting a computer to Garmin. I have it in my car and resetting hasn't worked. any suggestions
The nuvi is being put into mass storage mode (the mode used to transfer data back and forth to a computer). This is usually caused by using the wrong vehicle power cable.
The correct cable is Garmin part number 010-10723-06.
http://www.gpscity.com/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi.html
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
I just bought a dual xdvd9101 indash dvd player and cant get the brake bypass to work
However, some units use different methods. Some require seeing a pulse (i.e., power-ground-power-ground-etc.), resulting in the annoying need of pushing the e-brake a few times before your video will pop up. This can generally be recreated by using a 3-prong switch (you can get one at AutoZone). Connect it backwards -- the ground to power, power to ground, and the "Load" to the Parking Brake wire on the back of the radio. Flip the switch back and forth a few times and sometimes the video will pop up.
Some fancier units cannot be cheated. They use an internal gyro mechanism that detects movement.
Some even feature bypass codes. By pressing a certain combination of buttons on the remote then entering in a code it will permanently allow video.
Be good.
Dual DVD
Play Dvd for few seconds until you hear sound
Press Stop Twice
Then enter on remote 26604 the press enter
Nov 15, 2009 | Car Audio & Video
DS Not turning on - both screens flash
Try this if you haven't yet.Take the battery out,read the voltage with a meter,If low your charger is not working.Also if no meter try reinstall batery.Good Luck. DS's are unpredictable,you could not touch it for another month and it will work.
Sep 05, 2009 | Nintendo DS Lite Console
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
VM L450
These units are known for having bad "operation units", which consists of the switch that selects camera or vcr and the zoom unit. If you try quickly switching back and forth between cam and vcr and at least get a flash on the display, that is problem. Also, you can try slowly moving the switch (very slowly) between cam and vcr and awtaching to see if the power LED comes on at all. I have replaced many of the operation units on this unit.
Oct 22, 2008 | Quasar VM-L450 Camcorder
Where can i get the manual for my cellphone (Sanyo 8500) coz I can't find where the wall charger plugs into????
Just next to the volume button at the top right. It is covered by a rubber sheath. It is the same slot for the microsd and the charger.
See the video on THIS page for more details.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 03, 2008 | Cell Phones
Display went out. Replaced it with new display unit.
Check you part numbers , if same the new one can be bad even the clock displays
Dec 15, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Garmin nuvi 200W GPS Receiver Logo
106 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
