Question about Amana ABB1927DE Bottom Freezer Refrigerator
My bottom door freezer is working ok, but the refrigerator is warm 60 deg. No air is coming from the vents, what is the problem?
  • Amana Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratormy bottom door freezer is working ok, but the refr - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 07, 2010
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
Lg lfx25960st not cool enough
1. What are your controls (freezer & refer) set at?
LG recommends 0 deg for the freezer & 37 deg for the refer.
2. The way a modern refrigerator works is, the freezer is cooled directly and cold air then is blown into the refer section. The incoming vents in a French door LG are at the back, top. Return are at the bottom. Make certain that nothing is blocking these vents and than the refer has good air circulation.
3. Vacuum the coils at the back of the refer. A large build up of dust, dirt, animal hair etc. will affect efficiency.
Apr 14, 2014 | LG LFX25960 Bottom Freezer French Door...
The Fridge froze all inside and the generator works constantly. The settings are set to medium. Nothing changed after turning the power off and then back on after a few seconds. I'm assuming the thermostat...
Check the vent door from the freezer to the refrigerator...when you turn the refrigerator off with the knob, does the vent door close. The bottom of your refrigerator works from the freezer blowing cold air through the vent to the bottom of the refrigerator. If it is turned all the way down, that should shut off the flow to the bottom. If any thing is broke there, it will continue to let cold air come down the vent, so check it out. The vent knob itself might not be working to turn the vent door down or off. There also, is a relay on the back of the refrigerator that controls the compressor on and off...it could be stuck in on position.
Oct 28, 2009 | LG LRTP1231W Top Freezer Refrigerator
Kenmore side-by-side freezer is fine but fridge is not
Yes, Airflow is what cools the frig. Check for frost buildup on the coils indicating a problem in the defrost components r a fan not running fast enough. Eric
Aug 18, 2009 | Kenmore 53092 / 53094 Side by Side...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Fridge only cools to 55 deg F
check the bottom of Ref. see if it close right, sometimes the rubber near the bottom parts broken.
Jul 08, 2008 | KitchenAid KSRS25IL Side by Side...
Kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
204 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
