Question about Peg Perego John Deere Gator HPX Ride on Toy
How long to charge 12 volt battery
I just bought the 12 Volt battery and there are no instructions with it...how long does it need to charge?
We bought a new one about a month ago, and the sales rep was very unhelpful in telling us how long to charge it for, so we just do it for 10 hours, our little man get's a couple of days ride out of it, between 4-5 hours ride time all up, hope this has helped?...
Posted on May 08, 2010
Yamaha 450 Kodiak battery not charging, new battery, volt meter not showing any voltage going to the battery
Hi Brian, get a digital volt meter and start the ATV measure the voltage at the battery or at the alternator it should read around 14 volts when charging, if it reads 12 volts the charging system is not working, check or a blown fuse or broken wire, if you can access the alternator directly measure at that point. It takes 14 volt output from the alternator to charge a 12 volt battery
May 06, 2017 | Yamaha 2005 Kodiak 450 Auto 4x4
Ryobi manuals
YOU CAN GO TO GOOGLE AND DOWN LOAD THE MANUEL.JUST TYPE IN INSTRUCTION MANUEL ROYOBI CORDLESS DRILL 1048-67479CS LITHIUM BATATERY CB 120L YOU SHOULD BE ABLE TO DOWNLOAD THE MANUEL
Aug 12, 2014 | Ryobi Ridgid 12V Cordless Flashlight 12...
12 volt rechargeable battery for child's riding toy
usually the charger has an indictaor light on it that is red/amber when its charging and then green when the battery is fully charged. does yours have this light?
May 14, 2012 | Peg Perego 12 Volt Rechargeable Battery
How do you charge the 12 volt battery with a 6 volt charger
  • A 6 Volt charger will charge a 12 Volt battery, it will just take twice the time to get the 12 Volt battery to full charge as a 12 Volt charger would take. V*I=W. It will take up to 36 hours to get a full charge from near dead but it will work just fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
24 volt charging problems .2 12 volt batteries 1 battery 16volts and the other about 9-10 volts
A 12 volt battery is actually 13.2 volts fully charged. If you are reading 16 volts, you are probably getting extranious voltage from the system somewhere, especially if the vehicle is running when you check the voltage. The alternator will put out about 15-18 volts to charge the battery normally, and yours may put out 28-32 volts to charge them in series, but the batteries, when disconnected, should never read more than about 13.2 volts each. Typically, it will read about 12 1/2 volts when disconnected. COMPLETELY DISCONNECT BOTH OF THE BATTERIES. If you still read 16 volts when it is disconnected, you must have a bad meter because the battery can't produce that much voltage, no matter what. (Six 2.2 volt cells connected in series inside the case.) Put the meter on a known good battery on another car that is not running and see if you get the same reading. It sounds like the other battery is almost dead, regardless, and it sounds like your series/parallel switch may be malfunctioning. (That is the switch that puts the battery in series to run the 24 volt starter, then puts the batteries in parallel to run the remainder of the vehicle on 12 volts. This is all assuming that you have a diesel vehicle with a 24 volt starter and that is why you have two batteries.
Aug 19, 2008 | Toyota Land Cruiser Cars & Trucks
Peg Perego John Deere Gator HPX Ride on Toy Logo
702 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
