Question about GPS
I have a GPS V that worked great until I downloaded the latest upgrade. Now it just has a screen blip at first start up and wont do anything else. The screen stays blank.
  • williamscons May 07, 2010
    It is a garmin GPS V it has 4 AA batteries which I exchanged for new and it still does it
    President:
  • 1,851 Answers
What brand - make and model - ? makes a difference - sounds exactly like a dead battery - charge it over night on the wall charger I have a GPS V that worked great until I - d5cd693.jpg
Posted on May 07, 2010
  • Gary Rice
    Gary Rice May 07, 2010
    Sadly your unit has been discontinued. I am not as familiar with your product as I am with the Nuvi line and others. I withdraw and wish you the best. Maybe some other FixYa guy will get you going.
    Best of luck with it.
    Gary
How do i update map and software data online for my trax 430
Hello.
HOW TO UPGRAGE SOFTWARE ONLINE
If you are used to using an atlas or other map, you probablyalready know that new maps are issued each year because of changes on theroads. The same thing applies to the maps on GPS units. This means that if youhave a GPS unit, you need to update your GPS software regularly to make surethat you have the latest information. Each GPS manufacturer makes softwareupgrades available for GPS unit owners. Here are tools and instruction below
USB cable (as tool)
1 Visit the website forthe manufacturer of your GPS unit, such as Garmin or Magellan.
2 Go to the"Support" section of the site and then the "Downloads"area. This is where the latest upgrades are available for download.
3 Log in if you already havean account or key in the serial number of your GPS unit. Typically you get onefree upgrade on your unit, which is tracked by the serial number, which is whyyou have to enter it or have an account.
4 View the latest softwareupdates once you are logged in or have entered in the serial number. If you areeligible for the free upgrade, you will see it listed with no cost. If not, youwill see a price listed by the upgrade. Prices vary by manufacturer andupgrade, but average around $80 as of 2010.
5 Download the upgrade to yourcomputer or order the upgrade disk. According to CC Electronics & Gadgets,there is no difference between the two upgrade files. If you want to do animmediate update to the unit, you should download the upgrade instead of waitingfor the disk to arrive by mail.
6 Connect your GPS unit toyour computer with the USB cable that came packaged with it. When you do, theGPS update software will launch on your computer. If you have never installedthe GPS software onto your computer, you will need to use the disk that camewith the unit to install it so that it will launch for you.
7 Confirm that you want tosync the unit with the upgrade file that you download, or on the disk if youare using a disk. This will install the upgrade to your GPS unit. When itcompletes, you will get a message on your screen letting you know that it isdone. You can now disconnect the GPS from the computer. Thanks
Sep 18, 2011 | Uniden TRAX-430 GPS Receiver
Tip
Motonav TN30 Firmware Fix
Motorola Motonav TN30 Firmware Fix
Does you Motorola Motonav TN30 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN30 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN30:
  1. Start by downloading the Motorola Motonav system software from Motorola from here.
  2. Extract the files onto an SD memory card.
  3. Make sure your Motorola Motonav is fully charged.
  4. Turn your Motorola Motonav off by holding the power button for at least 8 seconds, until the charging LED indicator blinks.
  5. Insert the SD memory card
  6. Turn your Motorola Motonav on. The software upgrade will begin automatically. Select “Yes to All” if prompted.
  7. The full upgrade process can take up to 15 minutes.
  8. When the software upgrade is complete, your Motorola Motonav will
  9. automatically load either the Map screen, Warning screen, or the Language Settings screen, depending on the state and configuration of your device.
  10. Remove the SD memory card from your Motorola Motonav navigation device.
The software upgrade procedure is now complete. Your Motorola Motonav is as good as new again.
I hope that helps.
_______________________________________________
Motorola Motonav TN30 Manual Download
Motonav TN30 Upgrade Manual
Motonav TN30 Firmware Download
on May 04, 2010 | GPS
Tip
Motonav TN20 Firmware Fix
Motorola Motonav TN20 Firmware Fix
Does you Motorola Motonav TN20 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN20 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN20:
I hope that helps.
Motorola Motonav TN20 Manual Download
Motonav TN20 Upgrade Manual
Motonav TN20 Firmware Download
on May 04, 2010 | Motorola Mobility MOTONAV TN20 GPS...
How to update map
I helped a buddy update his Uniden GPS (Trax350). Simply follow these steps and you should be done.
Uniden's MapTrax350 GPS device accepts voice-command programming and provides detailed audio commands, as well, speaking aloud the map directions that are displayed on its screen. Keeping your Trax350's firmware updated is crucial to keeping it working correctly. Usually, you can go to a company's website and download the latest software, but with Uniden, you must register your product first to access the proper free upgrades. It takes minutes.
Instructions
things you'll need: USB cable
1 Navigate to the link in the Resources section and fill in the required fields. Click on "Register."
2 Turn on your device and connect it to the computer using its USB cable.
3 Log in to the site with the password that was sent to your email address after you registered the device.
4 Choose "Software Upgrades." Select the MapTrax350 device, and the latest firmware upgrade will appear. Click "Download."
5 Select "Save File" and choose a location on your computer to save it to. After it has downloaded, double-click the program icon, select "Run" and follow the prompts to update your Trax350.
Mar 21, 2011 | Uniden GPS
I got files from internet to update 2009 map for my gps, but I don't know how to get them into the gps.
1. Download the SONYNAVU_U73T_3.2.CN.BIN file to a temporary or download directory.
2. Connect your nav-u personal navigation device to the computer using the supplied USB cable.
3. Power on your nav-u personal navigation device and wait until the "Connect to PC" message is displayed on the nav-u screen.
4. Start the nav-u Tool software on the computer.
5. At the "nav-u tool" window, click "Upgrade System".
6. On the right side of the Upgrade Screen, verify that the target version is 3.00.
7. On the left side of the Upgrade Screen, click the "Browse" button, and go to the directory where the SONYNAVU_U73T_3.2.CN.BIN file was downloaded and then click "OK".
8. In the "Name" box, click to select "3.02 cn NV-U73T" update, and then click the button.
9. After the update file is transferred to the nav-u device a "Transferring Upgrade file completed." message is displayed on the computer.
10. After the system software update is complete, the nav-u device will automatically shut down and restart.
Mar 18, 2010 | Sony NV-U73T GPS Receiver
Tip
I hope that helps.
on May 04, 2010 | Motorola Mobility Motonav TN30 Car GPS...
I have a Garmin 885 the sceen does not work. touch keys do not work. I cannot get past the Garmin start up when plugged in . when I unplug it I get the warning page and select ok and get pge with wheree ti...
I recommend attempting a hard reset of your Garmin Nuvi 885.
Then I would upgrade the system software to the latest version. This often brings back unresponsive Nuvis.
Perform the Hard Reset
  1. Power the unit off.
  2. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  3. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  4. Press "yes" and the unit will reboot.
Upgrade the System Software
The upgrade software is a download available from Garmin. Installation steps are detailed here.
I hope that helps.
Dec 30, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 250- goes to blank screen when u hit SPELL
Sounds like corrupted firmware. Go to www.garmin.com and download their webupdater. Run it and connect a USB cable between your Nuvi and the PC. Let the webupdater look to see if there are any firmware updates. If so, install them. If not, let it reflash your current version.
- Jim
Nov 27, 2008 | Garmin nuvi 200W GPS Receiver
Where can I get the latest update or downloads for GPS Pioneer avic-s1
Yes I called the Canad number 1-877-283-5901 and they asked for 150 $ for this upgrade. Now a day, one can buy a cheaper new GPS in that amount. I am not going for this option.
Dec 26, 2007 | Pioneer AVIC-S1 GPS Receiver
SCREEN PERMANTLY STUCK ON
I had exactly the same problem. Helpline totally useless.
Ans. I returned mine to Halfords and they gave me a new one that works fine!
Mine only develpoed a problem when I downloaded the latest Tomtom home from their website. They have seriously bad software issues.
Oct 29, 2007 | Tomtom GO 700 GPS Receiver
GPS Logo
53 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
