Question about Brother IntelliFAX 3800 Plain Paper Laser Fax
RECEIVING FAX FROM COMPUTER
When people fax in from a computer our fax will not receive and vice a versa when we fax to a computer it does not go through
leroyal
  • 2120 Answers
SOURCE: fax will not send
Does the receiving or sending party have a DSL phone line?
Posted on Sep 01, 2008
  • 5 Answers
SOURCE: fax machine not receiving
David Powell Loves Katie Stone!
Posted on Oct 08, 2008
Toptech
  • 13 Answers
SOURCE: can't receive faxes but can send them okay
The easiest thing to check is the recieve mode setting. most of the time when this happens the machine is set on manual recieve. Set it to automatic recieve and you should be fine.
Posted on Oct 29, 2008
  • 10 Answers
SOURCE: Trouble faxing and receiving fax from "Brother 575".
Try changing the "Bandwidth Saver" settings on your Vonage account from the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
Hopefully this will work for you.
Dave Grannas
Posted on Jan 25, 2009
leroyal
  • 2120 Answers
SOURCE: Need to reprint previous fax.
you can't. check the journal for the last receive transaction fax number. send a request for re-transmit.
Posted on Mar 12, 2009
HP OFFICEJET 6500 SAYS NO COMPUTER CONNECTED WHEN RECEIVING A FAX, BUT PRINTS FROM THE SAME COMPUTER
to receive fax, you must connect the fax line to the printer. All-in-one printer can received fax without computer.
Sep 26, 2011 | HP Officejet 6500 Wireless All-in-One...
My internet service is via telephone line - I think this is the problem - but hoping there is a solution.
It can work. If it is dial up service you can not send or receive a fax while online and vice versa. If it is DSL you may need a DSL filter either from you internet provider or a store like Walmart, Best Buy, or any store with computer accessories. You can check with your internet service provider to see which kind of service if you aren't sure and if you need a DSL filter for your fax.
Mar 13, 2011 | Office Equipment & Supplies
Error #252
This is a poor fax line error. The line quality has noise or some issue causing the fax receive /or send to fail , often people use the same line for faxing and ADSL (telephone provided internet) and this will cause noise on the line. To fix this I have used a noise filter that came withe the DSL router from the Telco. sometimes ive even had to use two, one on each end of the phone cable before the line was clear enough to send and recieve faxes without a problem. If this is not your case, have the person sending the fax do one at a time or vice versa. Hope that helps you Gurvy
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have a lexmark all-in-one printer, model # x4270, when I fax someone, when received, the fax is a blank sheet of paper?
try and make a copy with the fax... if it comes out the same way... turn the paper face up if it was face down or vice versa and try again... if it works then fax the same way and see what happens... if all goes well then keep copying and faxing that way... if that works but fax does not work... print an internal report... if that does not print then you have main board problems... if internal prints print then you have a problem with your ccd... thats a big long strip that rests right under the keyboard... thats what does the scanning... if that is bad... then when you fax... or copy it will be blank or black... depending on what is blown on it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
No Signal after switching from digital input to analog vice-versa
What type of video connection is on the graphics card?
Test the monitor on a different computer to determine if the monitor is functioning properly.
Oct 06, 2009 | Acer X193W LCD Monitor
My hp printer fax does print when recieving a fax but doew print normally when coming off computer. Fax machine sya low on ink should I check both cartridges and get new ones
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Jul 10, 2009 | HP 920 Plain Paper Fax
LEXMARK X5495 New printer, can't send receive faxes
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines
Jan 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Not receiving fax on my Lexmark X6570 coming from a computer
on a lexmark if someone send you a fax ,first the machine has to be in fax mode ,then when the phone start ringing you have to press the start button or #9 button
Oct 03, 2008 | Office Equipment & Supplies
When sending the fax, the person is not receiving it, even though the transmission report says it was sent.
I think the receiving party has given you the wrong fax number. Your faxes are going to some other fax machine or their computer.
Sep 15, 2008 | Brother Office Equipment & Supplies
Lemark 5400 can't faxor rec fax give phon lone error message
If u have DSL modem ..u need to have a splitter for the fone line.....and then....the connections need to be right...
Phone line to splitter -splitter to Fax mech(Line Jack)...
Problem Receiving--
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
Jun 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Brother IntelliFAX 3800 Plain Paper Laser Fax Logo
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
