Question about Clarion Car Audio & Video
Wiring for Clarion Max973HD
I purchase a second hand Clarion Max973HD but the ISO wiring loom doesn't fit into the back of the unit, it needs a 20pin plug but I can't find one anywhere.
any help would be great
scott
RAC_ICS
  • 143 Answers
SOURCE: I need a wiring diagram
to what car is it being fitted?
standard stereo wireing is as follows:
SPEAKERS
+White -White/black Front left
+Grey -Grey/black Front right
+Green -Green/black Rear left
+Purple -Purple/black Rear right
POWER
+12v Con Yellow
+12v Ign Red
+12v Antenna Blue
-12v Return Black
Tele mute brown
Illumination Orange
Hope this helps somewhat.
Posted on Dec 23, 2007
SOURCE: I require a wiring diagram for Clarion radio/cassette PT8006B.
Dear FixYa, I accessed the internet and was led to your site in an attempt to resolve a wiring problem. I am not in a financial situation whereby I can afford to pay for this privilege. Thank you for your trouble.
Posted on Mar 23, 2009
  • 40 Answers
SOURCE: wiring diagram
http://www.kiatechinfo.com/index.asp
Good source for Kia its free to register NO STRINGS
Posted on Jun 01, 2009
  • 3 Answers
SOURCE: Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Posted on Mar 03, 2010
m111den
  • 94 Answers
SOURCE: Vodafone are having probelms fitting a hands free
hi
normally nissan use a 1 or 2 plug loom, as long as noboby has butchered it to fit aftermarket radio, shouldny have a problem getting a loom. try daltac.co.uk.
hope this helps
Clarion cd changer manual
My suggestion would be to check out your local ICE specialist or find the local Saturday night car gathering and see who they recommend.
Sep 05, 2014 | Clarion Infiniti I35 Nissan Maxima Cv737...
NONE OF THE OVERHEAD INTERIOR LIGHTS WORK. THE DOME LIGHT DOESN'T WORK EITHER. THE ONLY LIGHT THAT COMES ON WHEN OPENING THE DOOR IS A LIGHT DOWN BY THE FOOT PEDAL. WE JUST PURCHASED THE CAR AND THE...
It is most likely caused by faulty wiring between the main loom and ccm that is located in the left hand side foot well under/in front of the front seat. If you remove the seat and lift the carpet you will find at least three sets of wires (black/red, blue/grey, and yellow/green) that are joined there - or at least meant to be joined there. You need to get all of the wires connected back up again (connect all of the same coloured wires together). If the area is wet then you will need to check the drainage channels in the area under the main battery, and possibly sunroof drainage pipes (if fitted), and the drain from the heater/cooler. You should also check the ccm to ensure there is no damage to the circuit board therein. Consult a qualified auto-electrician if in any doubt. The fault seems to cover all passat-based cars prior to 2010 and after 97 (my '97 passat and '02 skoda superb both had problems here).
Sep 13, 2011 | 2006 Volkswagen Passat
I have an acura 2000 tl and the radio wiring harnes was cut off is there a diagram for this or is there a plug in adaptore so i can use the factory boss system and navigation with a diffrent radio
Hi Alberto,
It will be difficult to purchase just the factory connector for the rear of your stereo and nav system. The best thing to do in this situation is to try and find a second hand radio loom from a car wreckers/junkyard and fit the radio loom in place or have a autoelectrician wire the second hand loom in place.As for the wiring diagram, I do have one but it is in 3 parts and you will need the factory plug to wire the loom into.Let me know how you get on and I will send you the diagram when you require it.
Sep 13, 2011 | 2000 Acura TL
I need a wiring diagram for a Mitsubishi Stereo DX-262AL. I want to replace it with a Clarion CD stereo, which I need to "marry" to the existing DX-262AL car loom. Any help much appreciated.
Option 1: If you haven't purchased any components yet.
If your Mitsubishi still has the original OEM (factory) wiring loom, then the newest method of connecting an aftermarket head unit (i.e. Clarion) is by using a 'snap-on' adaptor harness which eliminates the need for any cutting/joining/soldering.
The adaptor you want is the Mitsubishi-to-Clarion type: one end of the adaptor has the Mitsubishi (female) plug and the other has the Clarion (female) plug.
These adaptor looms can be purchased from most automotive accessory shops, or you can purchase very cheaply online from Ebay.
Check this link (this is the Clarion MAW2-16 adaptor for 1995-2004 Mitsubishi vehicles) @ USD $1 + $11 shipping (Note: the Year of your vehicle will determine which harness you require):
http://cgi.ebay.com/CLARION-MITSUBISHI-FACTORY-WIRE-HARNESS-ADAPTOR-95-2004-/370521783457#vi-desc
Option 2: the hard way
If you REALLY want to do it the hard way and start cutting wires, then here is the wiring colour codes:
EARLY MITSUBISHI AUDIO CONNECTORS:
LATER MITSUBISHI AUDIO CONNECTOR (SINGLE TYPE):
I trust this answers your question? :-)
"If this has helped you, please take a moment to rate this solution. As always, I do appreciate personal testimonials from Fixya customers, after I have offered technical support. Thank you."
Sep 08, 2011 | Car Audio & Video
hi
hope this helps
Feb 19, 2010 | 2003 Nissan Altima
Car cd player installation
Yes it will, there is a short wiring loom between the headunit and the cars loom. they are universal and just plug in and away you go.
May 04, 2009 | Car Audio & Video
Replacing audio equipment
Asked at a car parts shop and they had the rightadapter being for the car make. Many thanks for responding and being able to help if needed. From Sue.
Jun 15, 2008 | Car Audio & Video
Wireing harness.
Hi diamante,
For your reference, pls see below image.
Further, here is a page of the official Clarion standard wirings and their color codes.
Here is a source of the connector for your reference. You don’t need the speaker connector since your unit does not have any built-in amps.
Additionally, if your vehicle’s wiring connections are not of the ISO-standard type or if you just want to verify, please follow this link for the installation adapters you may need to fit your Clarion DRX-9675Z CD Player to your particular vehicle.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | Clarion DRX-9675Z CD Player
Car Audio & Video Logo
66 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
