Question about KitchenAid KCGB200TG Grinder
My grinder is running but not grinding. I've vacuumed it out and removed all the excess grounds, reloaded it and it just whirrs without grinding a bean.
    Problem Solver:
  • 4 Answers
Sounds like a broken shear pin
Posted on Jun 01, 2010
  • UncleBen Jun 01, 2010
    I found a 3/32 x 1/2 inch pin at Home Depot in a package for 2 for for 46 cents + Tax, it works great!
My Odea Giro stops working when entering the brew pump cycle. When I run it without coffee it runs fine. When I add coffee it stops after the grind cycle. I have replaced the microswitches and cleaned the...
I had a similar problem
Mine was caused by an "oily" type of coffee beans. Grind was accumulating in the grinder.
I did open the machine and cleaned the grinder physically. At least, try to remove all beans and sucked with a vacuum the interior of the grinder screw.
Good luck
Jun 18, 2014 | Saeco Odea Giro Plus Coffee Maker
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
Saeco Grind and Brew model IDR 008 TG first the grounds were backing up and door not opening to go into basket, cleaned the dispenser per directions.. now the beans do not even grind at all nothing is...
Your grinder needs cleaning- maybe oily beans got used and/or storing beans in refrig/freezer? Both are a problem for grinder. Also, grinder should not be set to "fine"- it will definitely cause clogging and the situation you point out. ----------- The powder from the coffee grounds seems to get caked in the grinder. The only way to get it out is to run hot water into the little opening where the grounds funnel into the filter basket. --------- This will help.Thanks.Helpmech.
Aug 25, 2011 | Saeco Vacuums
Blade turns slowly and will not grind.
1. This fixes almost all the "beans will not feed or beans will not grind" problems unless you need a factory part for repair.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind.
Nov 25, 2009 | Cuisinart Coffee Makers & Espresso...
The grinder runs but does not grind the coffee beans
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Nov 12, 2009 | Saeco Royal Professional Espresso Machine
All of sudden my grinder plugs up. coffee settles in around the base of the burr and does not seem to fall into the grind bucket, so the machine still runs but grinding basically stops as no more more...
Nov 03, 2009 | Solis Maestro Electric Burr Grinder
I have a gaggia syncrony logic.The coffee beans are not going to the grinder so the grinder is just spinning,we have cleaned the machine and cant tell if something is stuck in it or what. cand you help?
Oct 27, 2009 | Coffee Makers & Espresso Machines
My A-9 Coffee grinder no longer grinds coffee. Have cleaned it and checked it out and nothing. The motor runs but no grounds. Thanks for your help!
Jul 21, 2009 | KitchenAid A-9 Electric Burr Grinder
I have a Divina Deluxe and the coffee grinder is moving but it does not appear to be grinding it justs runs until the cycle stops. The machine turns on and gets ready but not grind. I have opened it up and...
Remove brew unit and check the grounds chute from the grinder, if that is clear, then re-insert unit, then when the grinder is grinding adjust to a coarser grind.
May 31, 2009 | Spidem Divina De Luxe Espresso & Coffee...
Spinning but not grinding
Dec 08, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
KitchenAid KCGB200TG Grinder Logo
198 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
