Question about HP Business Notebook 550
I recently had my screen crack on my Hp 550...How do I know if a LCD is compatable? Will any LCD made by HP work if it is the same size (15.4")? How do I find my model number
    Problem Solver:
  • 7 Answers
I did a google search and it took 5 secs to find a replacement screen. look under your unit for serial numbers/model numbers etc this will enable you to fine tuine your search and get a compatible replacement. The new one should then work fine. Alternatively you can always plug in a external monitor.
Posted on May 07, 2010
  • 27 Answers
If you are referring to an external LCD monitor, any LCD monitor will work as long as the connectors are the same. VGA to VGA or DVI to DVI, otherwise you have to get an adapter.
To know what kind you have, if your display ports is 3 rows of 5, that is a VGA port. If it is 3 rows of 8 holes, that's a DVI.
Now to find the model number without turning it on, on the bottom of the laptop you can find a service tag. PRODUCT will tell you what the model number is. Also, you can find this info on the battery.
Hope this helps! Please don't forget to rate the answer. Thank you!
What size breaker
Rule of thumb:
Typical residential water well is 1 to 2 Hp @ 240volt
Use a double 20 amp breaker and 12 gauge wire up to 2 Hp pump/ within 100' distance
Use double 30 amp breaker and 10 gauge wire for 3-4 Hp pump/ within 100'
http://waterheatertimer.org/images/Amp-draw-for-motors-550.jpg
http://waterheatertimer.org/Color-codewire.html
Gene
h
Aug 11, 2014 | Electrical Supplies
LCD HELP!
When you go to this WEB site foe LCD screen parts, just enter the make and model of your laptop.
LCD screens and Inverterswww.lcdparts.net
Dec 29, 2011 | HP Pavilion Computers & Internet
Hi, i just want to know,my hp 550 display is always show me blank(from yesterday),what can i do now?or how can i solv it?pls
Is the display blank when you power on.?
First turn off notebook.Remove battery and power cable.Then hold power button down for 15 seconds.Reconnect battery and power cable.
Try to hit F10 key immediately when you power-on the notebook.
>If you are able to see bios(blue,grey,or white screen) information,then the issue is with windows or with drivers.
>If you are not able to see any screen.Then probably issue with graphics chip on motherboard.Contact Hp for repair options or authorize Hp store.
Thankyou.
Sep 08, 2010 | HP Business Notebook 550
Why would my HP laptop screen go black?
A few reasons
1) backlight burnt out (or broken)
2) loose or broken cable AND backlight burnt out (or broken)
3) Failed GPU (probably integrated into the motherboard on that model)
4) failed motherboard (same issue above)
Check by plugging in an external monitor- if you get a signal, your LCD need a new backlight (or inverter, an easy fix under $15 USD)).
Cheapest solution is to simply replace the backlight, but you'll have to diassemble the entire laptop lid/cover AND the LCD to get to the backlight at the bottom. (this could be under $20 USD to do). Often similar sized LCD's with different part numbers will work fine in different laptops (meaning, a 14" LCD mady by samsung or LG will be compatible with almost any same 14" LCD made by either, especially if it comes WITH the inverter!)...
:D
Sep 04, 2010 | HP Pavilion dv2000t Notebook
Need tip size for viewsonic powere supply
insidecomputer_2070_4186448
Replacement Part Number: 1267-0526
Specs:
  • 40 Watt, 12 Volt AC Adapter
  • 4.8 mm Barrel Connector with Positive inside
  • Condition: New
  • Warranty: 12 Months
  • 100% OEM compatible, Guaranteed to meet or exceed OEM specifications
Compatible Models:
  • Hewlett Packard Jornada 680 Series
  • Hewlett Packard Jornada 720 Series
  • Hewlett Packard Jornada 728 Series
  • HP Jornada 680 Series
  • HP Jornada 720 Series
  • HP Jornada 728 Series
  • Planer LP150-BK
  • Viewsonic VG150
  • Viewsonic VG-150B Model
  • Viewsonic VG151
  • Viewsonic VP140
  • Viewsonic VP150M
Sep 07, 2009 | ViewSonic VG151 15" Flat Panel LCD Monitor
I have a HP Pavillion TX 1000. Did everyone heard
It is highly improbable that heat from the CPU can crack a LCD screen. Even if the fan was faulty the CPU would have shutdown (thermal overload) before it would affect the LCD screen. If you apply pressure to the face of the LCD screen or twist the screen or impact the screen with a hard object, any of these will cause the LCD screen to crack.
Jun 11, 2009 | HP Pavilion tx1000z Notebook
HP tx1000 touchscreen won't work
These TX1000's have their fair share of issues, and this one is the most costly (potentially) to resolve.
There are two, and only two, possibilities for why the digitizer in the LCD isnt working.
1) On many occasions, I'd estimate about 40% of the time, there's a little cable inside the LCD housing and behind the LCD itself that connects to a daughter-board, which then is cabled to the mainboard. This little cable sometimes comes loose, and a simple reconnect will resolve the stylus pen issues.
2) The digitizer in the LCD has failed, no separate LCD+digitizer purchase, oh no no no....Gotta get the whole damn assembly. Part# 441106-001 at roughly $550 exchange from HP.
-Sy
Jun 02, 2009 | HP Pavilion TX1000Z 12.1" Touch Screen...
HP Business Notebook 550 Logo
75 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
