Question about Cartier Tank Francaise W51001Q3 Wrist Watch
My cartier tank is difficult to wind. The step is
My cartier tank watch is difficult to wind. The stem is hard to grasp because it is so smooth.
    President:
  • 2,501 Answers
Your watch is a quartz type that does not need winding.
If you go to their web site (http://www.cartier.co.uk/#/show-me/timepieces/w51011q3-tank-fran%C3%A7aise-watch-medium-model?tab=2" and you will see details of your model.
Posted on May 08, 2010
How do I wind a Cartier ballon blue watch ?
more than likely it has a screw down crown. Turn the crown towards you to release it from the case tube then wind it forward. Make sure that you tighten the crown when finished winding it or you will get water into the watch.
hope this helps, gabe.
Oct 22, 2014 | Cartier NEW CARTIER BALLON BLEU LADIES...
How to wind up an invicta
Unscrew the crown by turning it counter clockwise until the crown is free from the stem. Then turn it clockwise six times. After this step push the crown in and continue turning it clockwise until it is once again screwed back on to them stem. DO NOT SKIP THE LAST STEP because although the watch will operate in the winding position it no longer water proof. A simple drop of water in the stem would mean death for your watch. If you wear the watch everyday I suggest you wind it once or twice a month.
Jan 01, 2014 | Invicta Watches
Roadster not winding properly?
Since the watch has a quartz movement, no winding is needed.
If your watch has stopped, return it to Cartier to have it replaced.
(to see their web site entry for this watch, go to http://www.cartier.co.uk/#/show-me/timepieces/w62016v3-roadster-de-cartier-watch-small-model .
Jan 17, 2011 | Cartier Roadster W62016V3 Wrist Watch
My Cartier Roadster does not keep time in my watch winder, all other brands work except this one. Any idea why, should the winder be set at clockwise, counter-clockwise, or bi-directional.
I believe the Roadster uses the 2892 movement and as such should wind in either direction. Find a competent watchmaker and ask him/her to check the automatic winding mechanism for proper rotation. I am assuming this is a real Cartier.
Jan 17, 2011 | Cartier Roadster W62019X6 Wrist Watch
How can i change my cartier crown due to the sapphire missing
mcdevito75 here, Best Bet is to look for a small watch repair shop in your area, Most likely another crown and stem will have to be ordered from Cartier.
Aug 20, 2010 | Cartier Santos W20056D6 Wrist Watch
Does anybody know which way i'm supposed to wind my cartier santos watch? Options: clock-wise, counter clock-wise, or multidirectional?? thanks
mcdevito75 here, Generally your Cartier watch is wound in a clockwise direction simply, due to how it:s made, in this direction the mainspring is tightened or wound and turning the crown in a counter-clockwise position only free wheels the winding mechanism. I would advise you wind your watch in a multi direction, however not to the very, very end of It"s winding capacity, once you feel the crown getting tension only 4--5 more multi-direction turns should be enough to maintain a good wind to your Cartier watch.
Aug 15, 2010 | Cartier Santos W20011C4 Wrist Watch
Hi, I got a pre owned cartier watch roadster chrono, i dont how to wind the watch, it has some type of screw like button. Thanks, Ron
mcdevito75 here, That may be a screw down crown to help maintain water proofing, Best Bet, look for a small watch repair shop in your area for help with your Cartiers functions, you can also try to contact Cartier online, Cartier watch.com
Jul 03, 2010 | Cartier Roadster W62019X6 Wrist Watch
I have a problem pulling out the stem to set the date on my Roadster. Can you help? I can't seem to grasp the stem securely enough to pull it out. Thank you
mcdevito 75 here, you should be able to get a finger nail just under the stem to lift the stem to set the time, day/date, first be sure the stem isn"t a screwdown type, gasp the stem and turn it to see, if it is a screwdown type, simply un-screw the stem then pull it out to set the time, day/date. If all fails your local or any jeweler can help.
Jun 16, 2010 | Cartier Roadster W62016V3 Wrist Watch
WHERE CAN I GET A RESERVOIR FOR MY CARTIER LIGHTER
The reservoir tank can be the bane of existence for a Cartier lighter owner. Unlike most butane lighters which have gas tanks integral to the lighter, Cartier utilizes a user removable tank. Cartier only warrants the tank for two years. I've also seen tanks that say 12 months. New Cartiers come with one spare tank. I've seen spare tanks come up on eBay from time to time, for $30 - $50. If not, picking up a beat-up Cartier on the cheap just to remove and use its tank is an idea. Cartier does not sell spare parts of any kind (other than flints), so if your lighter needs a new tank they will probably insist you get a complete maintenance service, which can cost up to $300.
Jul 16, 2009 | Cartier Tank Solo Watch
How to set time on cartier chronoflex?
to set the time and date of cartier watch , full the crown at half setting possition then wind it until the date move push the crown to the normal possition then full the crown twoo times to time setting possition then wind it again until you search the correct time,fush the crown to the normal possition after setting,
Aug 24, 2008 | Cartier Watches
Cartier Tank Francaise W51001Q3 Wrist Watch Logo
679 people viewed this question
Top Cartier Watches Experts
k24674
Jimmy Accardi
Are you a Cartier Watch Expert? Answer questions, earn points and help others
