Question about Lite On LVW-5006 DVD Recorder
Lite On disc writing failure
My lite On DVD recorder is 2 1/2 years old and has started to fail writing R+ discs properly. I noticed about a year ago that when I record on R+ discs and finalize them, I want play them in another dvd player and that player will not recognize the disc. RW+ discs work o.k. I compared an older recorded disc to a recently failed disc and noticed a skipped space from where the recording should have started near the spindle hole. I wasted a few discs by testing the recording after a thorough cleaning of the unit. I went so far as to remove the cover and directly clean the lense and air blow all the components. It STILL in not working right. Also I have the same door close problem. Any recomendations? Thanks, K
Try updating the rom by downloading from lite-0n
Posted on Aug 17, 2008
Lite on burner will write but cant read
Now I LIKE Liteon very much. THey never give me any trouble and as long as you keep the lense clean, they burn for years upon years to come. Okay, so it CAN write, but can't read? Very odd indeed. I would strongly suggest first buying a CD Lense Cleaner disc. Don't be cheap. Get Memorex or Scotch 3M. I would Suggest Memorex because the brushes on THAT disc are SPECIALLY-designed to clean the lense, but NOT to damage it. Next, try installing Nero Ultra Edition and do a Burn-in or a Read/Write test with a CLEAN CD or DVD and see if it will tell you the Read/write data rate. If the lense is just a BIT dirty, it WILL give you those kind of problems.
Mar 25, 2014 | Lite On Computers & Internet
I have a LG DR 389 recorder:it refuses to read certain discs it has recorded-I have been using imation DVD-R and R. I noticed sometimes by removing the recorded disc immediately it is ejected the problem...
Region error code comes up when trying to play a disc.Has worked fine for 2 years, no setttings have been changed. Even new discs give thge same error
Aug 13, 2010 | Televison & Video
My lite-on DVD writer is not reading any dvd's as well not writing any DVD's while it is good for CD's..... What is the problem?? How can i correct my DVD writer
Hi Please try and use a different brand of DVD discs. DVD disc quality is sometimes an issue with lite-on drives Also check that you have updated drivers and your media burning software is installed correctly. Again if your using NERO this can be a problem. Try using any other burning software One other thing to try when recording DVDs set the recording speed to lowest Many Thanks Andy
Apr 27, 2009 | Computers & Internet
Failure in tape to disc transfer
what kind of software are you using. I have had problems with this type of transfer and I had to use a special transfer device. If you want to know about the device write back and I will tell you how I did it.
Jan 07, 2009 | Lite On LVC9006 DVD Player/VCR
I have a Lite-On LH20A1P dvd drive. The problem is, it starts to write and the about a minute later it kicks out the disk saying - could not perform end of Disc-at-once. Then burn process failed. Could...
-There a lot of things we may consider.I'll give some few things.
-It may be your dvd drive is not working properly.
-It maybe the setting of your dvd drive is not configure properly.
-It maybe the blank disc is having the issue not the dvd drive.
follow this steps to check and troubleshot:
-Set the dvd region
right click on my computer select properties, go to device manager click the + sign under dvd drive, right click on you dvd drive-choose dvd region.
-Enabling CD recording
Click on My Computer-right click on dvd cdrom drive-go to properties-select recording, then check if the Enable CD recording has a check on its box, then check the box that says Automatically eject the CD after writing.
If this steps will not work then send me feedback so we can move on to the next level of troubleshooting.
Oct 12, 2008 | Lite On Computers & Internet
Will not record onto blank DVD's from HDD on LVW-5045 HDD-DVD 160 gb
Hi Barry - I too have a Lite-on and was initially over the moon with it. For the last year or so I have been unable to "read" disks and was just using it for the hard drive for recording - but this weekend my father in law had the exact same problem occur to his Lite-on and he bought a dvd cleaner (£5) - used it and it solved it - So I tried it and presto mine is reading and writing fine again - I was so chuffed - need to share this simple info just in case its a simple "dust" problem for anyone else that is having reading problems. DVD cleaner not just a CD cleaner as DVD cleaners have two brushes on it.
Jan 02, 2008 | Lite On LVW-5045 DVD Recorder
Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Dec 11, 2007 | Lite On LVW-5045 DVD Recorder
Lite On LVW-5006 DVD Recorder Logo
465 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
