Question about Cisco CallManager 4.x (CM4XUK97825)
Voice product interoperability between cisco and huawei
How about the interoperability between cisco call manager and huawei's soft3000. i want to use SIP trunk to connect cisco call manager and huawei software switch,does it work? there are some ip video phone managed by Call manager.
ward_knutson
  • 64 Answers
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
  1. Press Settings.
  2. The Network Configuration lock symbol must be unlocked. If not, exit to the main window and press ** # again.
  3. Press 3 on the keypad (or scroll down) for Network Configuration.
  4. Press 33 on the keypad (or scroll down) to Erase Configuration.
  5. Press the Yes softkey.
  6. Press the Save softkey.
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
Posted on Nov 25, 2008
  • 121 Answers
SOURCE: want to migrate fom sccp to sip protocol for cisco
Here's a great little document from Cisco directly, called "Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the Reverse Process"
Easy to do, just follow the step-by-step directions.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Posted on Feb 20, 2010
  • 17 Answers
SOURCE: Why can't I connect my corporate Cisco IP Phone
Connecting a hub or switch to the "PC" port on the back of the phone is not a recommended best practice by Cisco as the IP phone does not support spanning tree protocol.
Posted on Jan 11, 2011
  • 17 Answers
SOURCE: I have cisco ip phones 7941 with the correct MAC
Make sure you have the phone configured as the correct device type in callmanager. Also, try and turn on auto registration in Callmanager as this will allow everything to register. Then go back and put the correct configuration the phone.
  • 65 Answers
SOURCE: How do i configure IP
Its a unmanaged switch.. I believe you dont need to configure it. It will work as it is
Posted on Mar 29, 2011
Huawei GE optical port with 1310 SFP module can connect to Cisco 3750X GE ports with GLC-LH-SMD?
The Cisco switch will probably err-disable the port when you plug it in. The workaround is to add these commands:
Switch(config)#service unsupported-transciever
Switch(config)#no errdisable detect cause gbic-invalid
It'll either work or it won't!
Feb 11, 2015 | Cisco Computers & Internet
Tip
Cisco 1841 Router, Hot Sales Product Cisco 1800 Business Router
The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase and integrated hardware-based encryption enabled by an optional Cisco IOS Software security image.<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841</a> dramatically increase interface card slot performance and density over the Cisco 1700 Series while maintaining support for more than 30 existing WAN interface cards (WICs) and multiplex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router).<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841 router</a> offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.<br /><br />Cisco 1841 router Product Details<br />Product Description Cisco 1841 router<br />Device Type Router<br />Form Factor External - modular - 1U<br />Dimensions (WxDxH) 34.3 cm x 27.4 cm x 4.75 cm<br />RAM 128 MB (installed) / 384 MB (max) - SDRAM<br />Flash Memory 32 MB (installed) / 128 MB (max)<br />Data Link Protocol Ethernet, Fast Ethernet<br />Network / Transport Protocol IPSec<br />Remote Management Protocol SNMP<br />Digital Signaling Protocol ADSL over ISDN<br />Features Cisco IOS IP Broadband , firewall protection, 128-bit encryption, hardware encryption, VPN support, VLAN support, Intrusion Prevention System (IPS), 256-bit encryption<br />Power AC 120/230 V ( 50/60 Hz )<br />System Requirements Microsoft Windows 98 Second Edition<br /><br />P.S. If you would like a new sealed Cisco 1841, the competitive price offered at RouterSwitch.com is US$586.00 per. Visit Cisco 1841 to see more...<br /><br />Notes: Router-switch.com is a World's Leading <a href="http://www.router-switch.com/">Cisco Supplier</a>, founded in 2002. It sells new, used and refurbished Cisco network equipment including Cisco routers 800/1800/1900/2800/2900/3800/3900 series, Cisco switches, Cisco Firewalls Security, Cisco IP Phones VOIP, etc.<br /><br />
on Jul 07, 2011 | Computers & Internet
What collaboration capabilities are available on the new Cisco 2900 and 3900 Series routers?
According to my experience and knoledge: the Cisco 2900 and 3900 series platforms have collaboration feature parity with the Cisco 2800 and 3800 Series platforms, so all of the following collaboration capabilities and solutions are present:
• Cisco Unified Survivable Remote Site Telephony (SRST)
• Cisco Unified Border Element
• Time-division multiplexing public-switched-telephone-network (TDM PSTN) and private-branch-exchange (PBX) gateways
• VoiceXML contact-center gateways
• Cisco Unified Communications Manager (UCM) media resources (allowing conferencing, transcoding, and Media Termination Point [MTP])
• Resource Reservation Protocol (RSVP) Agent
• Cisco Unified Communications Manager Express (CME)
• Cisco Unified SIP Proxy
• Gatekeeper
Cisco 3900 Series Routers
Jun 25, 2014 | Computers & Internet
I AM TRYING TO SET UP MY VOICE MAIL, BUT EACH TIME I PRESS THE MESSAGES BUTTON, ALL I GET IS A RECORDING WHICH TELLS ME TO CONTACT THE OPERATOR. SO THEN IT TELLS ME THAT THE OPERATOR IS NOT AVAILABLE.
That is because you need to setup the voice mail in Cisco Unity and also setup the phone in the call manager. Unless you have voice-mail setup it states.....Cisco Unity Messaging system....is the beginning of the message.
Aug 07, 2009 | Cisco 7940 IP Phone
Does HP ProCurve 1800-24G 24 Port Switch can act like a cisco router e.g. 2800 series or others
The Procurve 1800 SWITCH series supports 802.1p, 802.1q VLANS, 802.3ad LACP, 802.3x Flow control, RFC1534 DHCP/BOOTP interoperation, the Cisco 2800 series is a ROUTER and dependant on its IOS version will support a multitude of routing/security features that the Procurve just isnt designed to do.
Mar 04, 2009 | HP ProCurve Switch 1800-24G, 22-Port Web...
Is 54g certified by the Wi-Fi Alliance?
54g products can be certified today by the Wi-Fi Alliance for interoperability with 802.11b products. Broadcom is working with the Wi-Fi alliance to accelerate interoperability testing among 802.11g products.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Computers & Internet Logo
130 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
