Question about Electric Kid Trax C6 Corvette Ride On
Battery charged but wheels will not turn-could be a burned out motor or other electrical problem-I just requested the battery connector repair kit(from recall). Not sure if that will fix problem.
  • mat_bagg
    mat_bagg Apr 07, 2013
    well they do turn intemittant not enough to move the car all conections good and batt is charged was running fine untiil i was stored for winter
I had a prob with my daughter's purple C6 corvette where car would charge up and turn on but wheels wouldn't spin. It turned out to be the part that makes the wheel turn. It happened to still be under warranty so I called and they shipped the part out. All I had to do was follow instructions for putting it on.
When you lift the seat you can see one on each side. Unfortunately I don't remember what they're called but maybe this info will help you get started somehow.
Posted on Jan 04, 2013
    Problem Solver:
  • 13 Answers
It is probably the battery or the connector. Those batteries are known for being junk and it isn't fair to customers at all. It is under powered, won't hold a charge and cost an arm and a leg to replace. I know I own one and finally got the solutions to overcome the expense to fix it. If you go to www.cammhsm.com you can get the scoop on it and save a lot of time and money and get away from that stock battery and charger and connector www.cammhsm.com
Posted on May 29, 2010
Data link connector wiring diagram
Doubtful. There are a lot of manufactures that will have plugs unused and nowhere for them to plug into. Start with the battery and make sure it is fully charged. Did this problem just happen?? Possible blown fuse/fuse link causing the electrical to have no power. There are usually several fused links on these older models that go to the starter. Have a look to see if one is burned up/broken and repair as necessary
Oct 04, 2015 | 1992 Pontiac Grand Prix
2004 gmc envoy xuv , battery light stays on , replaced battery and checked alternator charging fine
You checked the charging voltage at the battery with a ? volt meter ? What was the voltage with the vehicle running ? 13.1 to 14.1 volts ?
BATTERY NOT CHARGING The IPC illuminates the battery not charging indicator in the driver information center when the following occurs:
The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage
Charge Indicator Always On
Step
Action
Yes
No
Did you perform the Diagnostic System Check for Starting and Charging? yes or no
Go to Step 2 yes
Go to Diagnostic System Check - Engine Electrical no
  1. Turn ON the ignition, with the engine OFF.
  2. Observe the Charge indicator on the instrument cluster (IPC)
Does the charge indicator illuminate?
Go to Step 3
Go to Symptoms - Engine Electrical
  1. Turn OFF the ignition.
  2. Disconnect the generator connector.
  3. Turn ON the ignition, with the engine OFF.
Go to Step 4
Go to Charging System Test
Test the charge indicator control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 6
Go to Step 5
5
Replace the PCM. Refer to Powertrain Control Module Replacement in Engine Controls 4.2L.
Did you compete the replacement?
Go to Step 6
6
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Aug 25, 2015 | GMC Cars & Trucks
Batteries charged fully, horn works, alarm sounds when key is inserted , wheels are unlocked but drive wheels dont turn when levers are engaged
This may be the motor controller. Usually it is a transistor used to drive the motor on this board. It can also be a loose or corroded connection. It can be also a low voltage problem (not battery related but wiring or other) or a internal motor problem.
If you can disconnect then reconnect each connector. If it is loose or dirty that usually is all it takes to fix it. If you can't do that you should take it into a repair shop. Usually the place of purchase will be able to tell you about any local repair shops. When you take it in try and tell them how it drove, what the battery charge was and if anything was abnormal the last time it worked. For example if it drove slower and slower and the just stopped. If there were any smells or smoke. A good repair shop will know whats wrong within a few minutes of looking at the scooter.
If you can work on the scooter you can get repair parts and everything plugs in and out. So if you can get the repair shop to tell you whats wrong or give an estimate then you can save a few dollars by fixing it. This saves the cost of labour. Most people aren't comfortable around electrics so if this is your case get a couple of estimates before committing to getting it fixed. You may get a better deal on parts or labour so it can pay to shop around from as many places as you can find.
Oct 24, 2010 | Health & Beauty
How do I replace the ac/heater blower moter?
Hope this helps....please don't forget to rate...thank you:
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  3. Disengage the wire harness connectors from the retainer.
  4. Disconnect the blower motor electrical connector.
  5. Remove the motor cooling hose.
  6. Remove the screws and remove the blower motor.
    NOTE
    Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
  7. Remove the wheel from the blower motor as follows:
    • Remove the push clip.
    • Remove the wheel from the blower motor.
Blower motor cooling hose
Blower motor mounting plate
To install:
  1. Install or connect the following:
    • Wheel to the blower motor, if removed.
    • Blower motor and securely tighten the screws.
    • Motor cooling hose
    • Blower motor electrical connector
    • Wire harness retainers
Sep 15, 2010 | 2005 Mercury Grand Marquis
Scooter battery shows full charge but scooter does not move ! red led light flashes 8 times !
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair Xpress@ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Sep 12, 2010 | Golden Technologies Liteway 3/4 Wheel...
My four wheel golden electic scooter is fully charged but went from fully operational to just clicking and not moving at all. Can you help?
Hi. I have had this problem on many machines. It is normally a stuck brush in the motor. This stops the motor from going. The click you can hear is probably the brake solenoid releasing.
Can also be a faulty connector in the motor or battery leads.
Good luck. Neil.
Jun 09, 2010 | Golden Technologies Avenger 4 Wheel...
Dashboard lights burning out, down to 1 illuminating tach, speedo, gas gauge. How complicated to replace?
one hour job. find bulb part number in bulb chart in owner manual.
go here for villager help.
http://groups.yahoo.com/group/villagerquest/
Section 13-01B: Instrument Cluster — Conventional 1996 Villager Workshop Manual
REMOVAL AND INSTALLATION Instrument Panel Finish Panel Removal
  1. Disconnect the battery ground cable (14301).
  1. Block the wheels (1007) to prevent the vehicle from moving.
  1. Turn the ignition switch (11572) to the OFF position.
  1. Shift the transmission range (TR) selector to MANUAL LOW (1).
  1. Tilt the steering wheel (3600) to the lowest position, if equipped with a tilt wheel.
  1. Remove the two instrument panel finish panel screws.
  1. Remove the instrument panel finish panel (044D70) enough to access the switch electrical connectors.
  1. Disconnect the rear windshield wiper/washer switch electrical connector.
  1. Disconnect the heated back window and light switch electrical connector.
  1. Disconnect the emergency warning switch electrical connector.
  1. Disconnect the SECURITY indicator light electrical connector.
  1. Disconnect the speed control on/off (CRUISE CONT. ON/OFF) switch electrical connector.
  1. Disconnect the headlamp switch electrical connector.
  1. Disconnect the autolamp/light switch rheostat resistor electrical connector.
  1. Remove the instrument panel finish panel with the switches attached.
Instrument Cluster
Removal
  1. Remove the four instrument cluster screws.
  2. Remove the transmission range indicator (7A110) from the instrument cluster (10849).
Jan 13, 2010 | 1995 Mercury Villager
Pride sonic scooter won't turn on. the battery is charged and the motor is functional. Appears to be an electrical switch. any suggestions?
How do you know that the motor is functional? Have you load tested the batteries. If the batteries are bad usually they will still take a surface charge and appear to be fully charged.
Jul 08, 2009 | Pride Sonic 3 Wheel Portable Scooter
Electric Kid Trax C6 Corvette  Ride On Logo
283 people viewed this question
Top Electric Toys Experts
Robert A. Watson
Robert A. Watson
Tom Chichester
 Russ Hill
Russ Hill
Are you an Electric Toy Expert? Answer questions, earn points and help others
