Explain the working of the wireless remote of the fujitsu split system air conditioner
    Guru:
  • 825 Answers
All remote controls work in same manner....
you can follow this link to know more about the working....this link has got the best answer according to my knowledge....
http://www.ehow.com/how-does_4567120_remote-control-work.html
you can also have a look on the list of sites by following this link....
http://www.google.co.in/search?hl=en&q=how+does+a+remote+control+work&btnG=Search&aq=f&aqi=g-c1g1g-c1&aql=&oq=&gs_rfai=
Posted on May 07, 2010
Split System Error
so like a faulty component look up Fujitsu web sight for trouble shooting should have answers on there web sight
Jan 03, 2014 | Fujitsu Heating & Cooling
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
How to use thermostat for heat on Fujitsu IAQ halcyon
This unit comes with a remote control (optional wall mounted wired thermostat available) as a standard feature. This unit is precharged with the environment friendly R-410a refrigerant. No additional refrigerant is needed if the line set is 49 feet in lenght or shorter. In addition to its very high 20 SEER efficiency rating, the 15RLQ is only 31 in. long which makes it the smallest Mini-Split System in its category through out the industry.
This category of equipment is ideal for smaller spaces where spot cooling is required. Several models in this category are ENERGY STAR Certified, meaning they save you money on your utility bill. Residential applications including sunrooms and additions are made easier with these air conditioners and heat pumps. Do you have a warm spot in your home? Fujitsu mini-splits can provide extra cooling capacity for those hard to cool areas. Commercially, their small size makes them ideal for small offices, providing individual temperature control.
Fujitsu's I.A.Q. Systems provide residential and commercial property owners an innovative solution for clean, temperature-controlled indoor air. The Halcyon IAQ systems deliver powerful heating and cooling, are designed for ease of use and maintenance, and feature an unobtrusive design which can be integrated easily into any decor. The Halcyon IAQ systems filter dust, pollen and odor making them the perfect addition to any home!
  • Wireless Remote Control
  • Plasma Filter
  • Sleep Timer
  • 24 Hour Timer
  • Dry Mode
  • Auto Louver: Up/Down
  • Auto Mode
  • Quiet Mode
  • Auto Restart/Rest
  • Auto Changeover
  • Low Ambient
  • Cold Prevention
Warranty All Fujitsu ductless mini-split air conditioners and heat pumps come with a 2 year parts and 6 year compressor warranty.
Important: All installations must be performed or supervised by a certified HVAC technician in order for the warranty to be valid.
Dec 08, 2009 | Heating & Cooling
Outdoor fan is running continuously without using Wireless Remote Controller
Bad control board on the condensing unit up top. The board needs to be replaced as it is sending the message that the system is calling for cooling/heating all the time and doesnt know what to do. If you continue to let it run this way you will ed up having more major issues
Jun 01, 2009 | Fujitsu Heating & Cooling
LG Split system (ceiling cassette)
Check your remote control by using your camera or cellphone camera as your eyes. Point the remote control to the camera and "on" the remote control. If no lights emits in the remote control means that your remote control is defective If lights emits then the remote control is ok. Try also to locate the reset or rst button on the remote control if available and reset it, then try. If it wont work may be the receiver board in the unit is defective.
Jan 14, 2009 | LG LSC121PMA Split System Air Conditioner
AC not working
Try opening the front of the machine and check the circuit board has not got anything on it the could cause a short. I had the same problem but mine was a gekko that fried on my circuit board.
Sep 25, 2008 | Fujitsu 12C1 Air Conditioner
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Dec 01, 2007 | Heating & Cooling
 Grubhead
Grubhead
