Question about Garden
My Poulan ES400 18'' electric chainsaw stopped working after about 2 hours of work. I cleared the debris and sand, checked the connections, oil level is half...misplaced my instruction manual and can't find one on line. Help please. thanks- WS
    President:
  • 2,220 Answers
If all you need is an OM I can help
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
ES400 returns this (I did not look for IPL).
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2010/NOUS2010_115259926.pdf
Did you try a different outlet (circuit breaker)? Different extension cord? If not what you need please post back below.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 07, 2010
My chainsaw poulan p3314 will run fine for about five minutes, then cuts out and wont start until it cools down....???
Sounds like the engine is overheating and seizing. Most of the time this is a cooling or oil problem. Check the cooling fan for debris. Make sure you use the right oil mix.
Sep 16, 2013 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I need a manual for a new Poulan 3.5 electric chainsaw, or, failing that, I need instructions on what kind of oil to use on it, and whether I need separate oil for the chain.
You shouldn't need any other oil than the oil to keep the chain and bar guide oiled (pressing down on the button adds more oil to the chain/bar). You can use standard Bar and Chain Oil, or probably pay a little more and use the Poulan brand oil, but in my experience, any bar oil for chainsaws will work, and the larger the container you buy, the less per ounce you will pay. Remember this is NOT an automatic oiling system, so it will be cheaper in the long run to remember to press that button than to replace the chain/saw if it overheats.
Aug 29, 2011 | Poulan 14" Electric Chainsaw
No chain oil is getting tobar. I've checked for blockage and cann't find any.
Very good chance that your oil pump has a stripped gear.This often causes the oil pump to stop working on these models.
Feb 20, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chainsaw(PP4218AV) worked for a while now won't start
It's possible that the carburetor diaphragm in the lower chamber has hardened or cracked. Does the primer bulb fill with fuel after several pumps? If not, try moving the line that comes up from the fuel filter to the carburetor over to the primer port that normally connects to the other carburetor connection. Try to pump fuel again--if successful, then there is blockage within the carburetor which should be cleaned with spray carburetor cleaner inside and out. There is a small filter screen inside the main body that can be easily plugged with stale fuel. Hope this helps!
Jul 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulan E300 Electric Chainsaw stop oiling the chain and bar
Hello JK; I am hesitant to answer this, these are all Poulan electric chainsaws that appear when the parts source is searched for Poulan Electric Chain Saws:
400E Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400E-Poulan-Pro-Electric-Saw/75.400E-Poulan-Pro-Electric-Saw.1.59.1.html
400EX Poulan Pro Electric Saw
http://www.ordertree.com/modelinfo/PWE/400EX-Poulan-Pro-Electric-Saw/75.400EX-Poulan-Pro-Electric-Saw.1.59.1.html
ES400 Electric Saw
http://www.ordertree.com/modelinfo/PWE/ES400-Electric-Saw/75.ES400-Electric-Saw.1.59.1.html
PP250E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP250E-Electric-Saw/75.PP250E-Electric-Saw.1.59.1.html
PP300E Electric Saw
http://www.ordertree.com/modelinfo/PWE/PP300E-Electric-Saw/75.PP300E-Electric-Saw.1.59.1.html
All are plumbed the same to my eye. I assume you cleaned and tested the oil pick-up within the tank. If everything you say is true if the pump is driven it should oil.
1. What causes the pump to pump? I cannot tell from the IPLs. If gas and not gear driven, an impulse line (pressure/vacuum) from the crankcase drives it. There can be no impulse line on an electric and I see no gear. Does it rotate to pump oil? What imparts the rotation?
2. What purpose does item 27 (pinion) serve? Is it supposed to drive the pump? Is it missing teeth?
3. What is the purpose of item 44 (check valve). If it is an oil tank vent, and not opening, you are creating a vacuum in the tank if the pump is operating. Loosen the oil cap and see if it oils. If yes replace the check valve.
I think Joe Schmoe is saying Poulan redesigned the oil system to eliminate all the hose couplings. It makes sense, one hose from oil pickup (filter on hose end in tank) to bar is much less likely to leak, also no restrictions for any particles in the hose to form a clot on. I see nothing on my research to support Poulan doing that. There are a couple of new models that I cannot find an IPL for so it is possible. I have headache JK. If this does not solve it is not because I did not give it my all. Please post back (below) with success or failure. If successful what was the cause. TIA
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 29, 2010 | Poulan Pro Chain Saw 46cc 20"
Filter screen on carb of a poulan pro chainsaw keeps glogging with a white powder. Carb has been cleaned and only used briefly. Use recommeded gas and 2 cylce oil mix.
Hello. If this powder is very fine saw dust its an indication of the filter doing its job. It may collect oil as well and create a paste like coating. Cleaning every 8 hours of use should be adequate.
builderdale
Jan 11, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan cahin saw,18" model. Starts ok. Will not rev up. Choke opens full. Filters clean. Used less than one hour since purchased. Hedley
If I purchased this new, mixed oil with the gas prior to adding it to the tank, and it only worked for hour I'd be standing on the service desk. Take it back. If you forgot to add oil to the fuel they may work out a deal on a reconditioned unit. It costs nothing to ask. HTH
Lou
Oct 02, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The bar/chain oiler has stopped working. What to check? Yes there is oil in the saw. If I have to replace parts, how do I remove the clutch?
Just an idea, but I would remove the bar and back flush the oiling port hole with some air pressure. Then if you are able to get the line and pump clear, I would flush out the old oil.
Could you maybe have got some sawdust into the oil reservoir?
Aug 29, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 18" Chainsaw - Motor runs fine but blade stopped spinning
Chain may be locked in the bar. Caused by low oil flow to chain. You will probably have to remove the bar and blade. Then try to rotate the sprocket, if it will not rotate you may have to replace or repair the clutch. with the blade off try starting the saw and see if it is oiling. There is a small hole in housing that oil should be visible coming out at a fairly good rate. If not you will either have to open orifice in the housing or repairing the oil pump.
Apr 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
311 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
