Question about Maytag MSD2756G Side by Side Refrigerator
Ice maker is not making ice
I have a maytag fride with freezer on the bottom. The icemaker is not making ice. what could be the problem?
    President:
  • 1,218 Answers
Good day,
The best way to get it up and running is a step by step procedure.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on May 07, 2010
Turning off the ice maker on my may tag refrigerator freezer
Hello, Suzanne -
Most ice makers in refrigerator / freezers have a heavy metal wire "arm" which activates and deactivates the ice making process. When the "arm" is in the down position, ice is made.
With most refrigerator / freezer ice makers, the "arm" can be set in the up position, so that the ice making process is stopped.
See information here:
http://www.acmehowto.com/howto/appliance/icemaker/check/shutoffarm.php
Best wishes.
May 08, 2018 | Maytag Refrigerators
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
Maytag MFI2067AES Icemaker is frozen and cannot be used. It is now a solid block of ice. Please don't suggest using a hairdryer. It does it all the time. Also a hairdryer is useless without dismantling the...
is the fill tube clog? the ice maker is not going to harvest mode. Take the ice maker cover off and put a jumper on T and H hole the dial will turn and wait until you hear the click remove the jumper. make sure you have gloves on. Do this at your own risk, if you are not sure call a servicer. If the dial won't turn you have a bad ice maker (if you have a 115 volts to the ice maker).
Nov 22, 2017 | Maytag MFI2067AES Stainless Steel Bottom...
Icemaker wont make ice.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Dec 14, 2010 | Maytag MFD2560HES Bottom Freezer French...
Icemaker isnt making ice but the water is coming out fine.
heatman101
Aug 26, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag bottom mount freezer (top) icemaker not working
check to make sure that your fill tube is not blocked with frozen water.
if there is no restriction then you have a faulty ice maker.
Apr 01, 2010 | Maytag MFI2266AE Side by Side Bottom...
Maytag MBB1952HEW won´t make ice. Where is the fuse to icemaker located? It´s not in the bottom freezer coil area.
back wall of freezer has thick layer of ice frosting over, freezer not cold frig compartment seems to be ok.///????
Oct 14, 2009 | Maytag 22.1 cu. ft. Bottom Freezer...
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Freezer making grinding noise ice maker not working
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
Maytag MSD2756G Side by Side Refrigerator Logo
128 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
