Question about Harman Kardon AVR 300 Receiver
Harman Kardon AVR 7000
Hi There
Getting intermittent breakdown in connection in all surround sound modes. Both DVD and satelite TV decoder audio connection is through coaxial. There are times that it works perfectly for days. On Dolby it start sounding like the voices are brubling, and on the digital to analogue modes, it gives a sort of a bgggggggg sound. Switching the amp off and on again, its perfect again. I checked all connections. Thought it may be a loose connection inside the amp?
  • Anonymous Aug 04, 2008
    Yeah I have the same problem .. tried to reset the processor .. still didn't work. checked all the connectivity inside the unit and it seems to be fine .... hmmggggg
Befor you go for bench time I would resolder all the board conectors for the ss prosesor board and preamp to amp board.
Posted on Apr 12, 2008
  • 4,234 Answers
This is most likely a problem with the processing chip/system. It could be as simple as a bad connection at the chips or the chips are having problems internally. This is not a problem that is likely to be fixed without bench time and test equipment. You're going to need to get this unit to a service shop for proper diagnosis.
Dan
Posted on Mar 27, 2008
How do to connect tv from AVR
audio out from tv to audio in on the avr
Apr 19, 2015 | Harmon Kardon Harman Kardon AVR 235...
I've just bought HK AVR 260 and have the following problem: Sometimes the sound disappears while changing the channels on my sat decoder, or while pausing and playing again on PS3, or while changing the...
This is clearly a manufacture defect right off the assembly line. From your description you have a serious intermittent problem with the AVR unit when it comes to selection and other choices and it will only get worse, I strongly suggest you return the item in favor of another.
Feb 09, 2011 | Harman Kardon AVR 2600
I hope this mail finds you well.i am not getting sound from the surround and center speakers.when i test my speakers i only get sound from the front speakers.
hi,
check ur speaker connection first or may be ur receivers speaker setup have some problem. except frond speaker all the others will be off mode. change the speaker setting.
press osd button on the remote to bring audio setup. select ur speakers large or Small or large according to ur speakers. then test again.
if u connected an analog audio input then press surr (surround mode button) to select the mod you want)
ok
Dec 18, 2010 | Harman Kardon AVR 7000
Fiber Optic input
No gots. The 3485 is pre-digital stereo-only.
From the manual, page 19
"You may have observed that the HK 3485 is not equipped with digital audio inputs or surround sound decoding. If you prefer the complete home theater experience, you may wish to consider purchasing a fullfeatured Harman Kardon AVR Series audio/video receiver. However, we hope you will find that using a DVD player with the HK 3485 in smaller settings, such as a bedroom or den, surpasses the audio performance of most televisions, including those with onboard stereo speakers."
Apr 13, 2010 | Harman Kardon AVR 240 Receiver
Hi dear. how can connect my dvd to hamman kardon
connect tv video in to kardon video out (tv audio in to kardon audio out) dvd audio and video out to kardio audio video in. and if you what to record also signal from tv. make a cable from tv audio / video out to kardon audio / video in.
Apr 06, 2010 | Harman Kardon AVR 135 Receiver
No audio from Harman Kardon AVR 7000
Incorrect polarity between receiver and speaker will not damage receiver however unmatched impedance speakers can damage amplifier section of receiver.
Please check connection cables in receiver and if receiver does not shut off in protection mode then it could be connection cable broken or some dry / cold solder joints on circuit boards in receiver.
Re-soldering of cold solder joints is job of qualified tech.
Sep 14, 2009 | Harman Kardon AVR 7000
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
Harman Kardon AVR 300 Receiver Logo
215 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
