Question about Envision EN-7410 17" Flat Panel LCD Monitor
My envision monitor lights up briefly with a welcome screen and then goes blank. I can see the computer images dimly in the background. does it pay to fix the problem? The model is EN7410e and it is 5 years old
  • 11,361 Answers
Please read below if you are going to DIY repair since you will have to open up the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 07, 2010
I have a Envision EN-7100e monitor. Downloaded
catamount309, This is only a guess, but unit may have internal "switch-mode-power-supply"/"CCFL inverter" board problem. When screen goes BLACK, is it also BLANK? If you can see WIN-desktop with aid of bright flashlight 1 inch from screen, then SMPS is in partial shutdown mode. If you see nothing, then SMPS is in full shutdown. In either case, Technician will need to repair the SMPS/CCFL inverter board. If KNOWN GOOD monitor works with PC, then you know 7100e is bad. Do you know and understand how the new energy efficient screw-in curlie-Q light bulbs work? If the "electronic ballast circuit" not working, then it can't light-up the CCFL tubes on the reverse side of LCD panel then you see black. Do more reading in my fixya profile for more options open to you. Do your research first!! Hey, reading is free!!!
Will you fix or trade for new? 12fixlouie
Mar 07, 2010 | Envision EN-7100e 17" Flat Panel LCD...
The screen went blank while the computer was on, we restarted it, the screen shows the Dell sign & the white bar then it goes blank, it won't go into safe mode, the light is green on the monitor, what...
If there is a faint image in the background it is the coils on the planar if no image it is either the invertor or the backlight
If you have a faint image resolder the coils or replace them
Dec 15, 2008 | Dell Dimension B110 PC Desktop
Monitor goes black but shows icons...
I'll assume this is an LCD panel screen.
If what you are saying is the screen shows up and then goes dim or starts dim, and you can see a dark image of the system starting up and then displaying Windows...
Your problem is a bad CCFL (Cold Cathode Fluorescent Lamp) at the top of the LCD panel.
If the screen is totally blank, then it may be the power inverter.
You can find many websites that sell these parts, but make sure you have the right model.
If you feel comfortable with working on computers, you can replace this part yourself. Otherwise, you may want to pay a technician to do it. Make sure to get a fixed price quote before authorizing the work
Here is a website on LCD repair for laptops, but it the same principal for display monitors.
http://www.ccfldirect.com/lcdtutorial.html
RDO
Nov 16, 2008 | HP vs15 15"LCD Flat Panel Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Laptop Screen dark yet computer works with external monitor
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
Jul 14, 2008 | Compaq Presario R3000 Notebook
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After going blank, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
Envision en 9110 lcd
More than likely bad inverter board or power boards
Nov 06, 2007 | Envision EN 9110 19" Flat Panel LCD...
Envision EN-7410 17" Flat Panel LCD Monitor Logo
169 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
