Question about GE 24 in. Profile PDW9200J Built-in Dishwasher
How hard is it to replace a leaking connector pump assembly, part # WD18X10010.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My dishwasher is leaking where the pump attaches
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
zcbnvG
Posted on Sep 29, 2010
Waterpump 2002 ford turaus 3.0 durtec
3.0L Engine
VIN S Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
  • Splash shield
  • Lower heater hose
  • Radiator lower tube bolt
  • Radiator upper front tube bolt
  • Air cleaner assembly
  • Battery and tray
  • Water pump belt
  • Upper radiator hose
  • Engine vent hose
  • Transaxle 10 pin connector
  • Radiator bypass hose assembly
  • Thermostat housing
  • A/C compressor brace, if equipped
  • Water pump mounting nuts
  • Connector hose
  • Water pump
To install:
  1. Install or connect the following:
  • Water pump
  • Connector hose
  • Water pump mounting nuts and tighten them to 15-22 ft. lbs. (20-30 Nm)
  • A/C compressor brace, if equipped, and tighten the nuts to 15-22 ft. lbs. (20-30 Nm)
  • Engine vent hose
  • Water pump belt
  • Battery and tray
  • Lower heater hose
  • Splash shield
2. Fill the cooling system.
3. Start the engine and check for leaks.
Dec 06, 2015 | 2002 Ford Taurus
1997 chevy cavalier change fuel pump
Hi there:
Check this procedure:
  1. Relieve the fuel system pressure using the recommended procedure.
  2. Disconnect the negative battery cable.
  3. Drain the fuel tank, then remove the fuel tank from the vehicle.
  4. While holding the modular fuel sender assembly down, remove the snap-ring from the designated slots located on the retainer.
WARNING The modular fuel sender assembly may spring up from its position. When removing the modular fuel sender from the tank, be aware that the reservoir bucket is full of fuel. It must be tipped slightly during removal to avoid damage to the float.
  1. Remove the external fuel strainer.
  2. Detach the Connector Position Assurance (CPA) piece from the electrical connector and detach the fuel pump electrical connector.
  3. Gently release the tabs on the sides of the fuel sender at the cover assembly. Begin by squeezing the sides of the reservoir and releasing the tab opposite the fuel level sensor. Move clockwise to release the second and third tabs in the same manner.
  4. Lift the cover assembly out far enough to detach the fuel pump electrical connection.
  5. Rotate the fuel pump baffle counterclockwise and remove the baffle and pump assembly from the retainer.
  6. Slide the fuel pump outlet out of slot, then remove the fuel pump outlet seal.
To install:
  1. Install the fuel pump outlet seal, then slide the fuel pump outlet in the slots of reservoir cover.
  2. Install the fuel pump and baffle assembly onto the reservoir retainer and rotate clockwise until seated.
  3. Install the lower retainer assembly partially into the reservoir. Line up all 3 sleeve tabs. Press the retainer onto the reservoir making sure all 3 tabs are firmly seated.
Gently pull on the fuel pump reservoir from retainer to assure a secure fastening. If not secure, replace the entire fuel sender.
  1. Attach the fuel pump connector.
  2. Fasten the CPA connector to the fuel sender cover.
  3. Install a new external fuel strainer.
  4. Install the modular fuel sender.
  5. Install the fuel tank in the vehicle.
  6. Connect the negative battery cable.
  7. Pressurize the fuel system and verify no leaks.
Fig. 7: The module fuel sender assembly is mounted in the fuel tank
Fig. 8: Modular fuel pump component identification
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 25, 2012 | Cars & Trucks
How do I replace the fuel pump on a 2000 kia sephia?
Removal & Installation
  1. Relieve the fuel system pressure.
  3. Remove the rear seat cushion from the vehicle.
  4. Clean any dirt that has accumulated around the fuel pump cover so it will not enter the tank during pump removal and installation.
  5. Remove the fuel pump cover.
  6. Disconnect the fuel gauge connector, hoses, and the gauge.
  7. Disconnect the fuel pump electrical connector.
  8. Remove the fuel pump from the bracket assembly.
  9. Remove the seal ring and discard.
To install:
  1. Clean the fuel pump mounting flange, fuel tank mounting surface and seal ring groove.
  2. Apply a light coating of grease on a new seal ring to hold it in place during assembly.
  3. Install the seal ring.
  4. Install the fuel pump to the bracket assembly carefully to ensure the filter is not damaged. Be sure the seal ring remains in the groove.
  5. Hold the pump assembly in place, and pull the fuel pump down so that it is tight against the bracket.
  6. Connect the fuel pump electrical connector.
  7. Connect the fuel gauge, hoses, and gauge connector.
  8. Install the fuel pump cover.
  9. Install the rear seat cushion.
  10. Connect the negative battery cable.
  11. Start the engine and check for proper system operation and for fuel leaks.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 24; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
Jan 16, 2011 | 2000 Kia Sephia
Do I have to drop the fuel tank to replace the fuel pump on a 94 Buick le saber
Yes ,,instructions are below, Use eye protection for this procedure
Remove or Disconnect:
  1. Relieve Fuel Pressure
  2. Disconnect negative battery cable
  3. Raise vehicle on hoist
  4. Remove Fuel Tank
  5. Remove Fuel Gage sending and pump assembly by turning cam lock ring counterclockwise. Lift assembly from fuel tank and remove fuel pump from fuel gage sender unit.
  6. Disconnect pump wires, hose clamps, and clamp around pump body
  7. Pull pump assembly out of rubber connectors
  8. Inspect fuel pump attaching hose for any signs of deterioration. Replace as necessary.
Install or Connect:
  1. Push fuel pump assembly into attaching hose
  2. Connect pump wires, hose clamps at attaching hose and around pump body
  3. Place Fuel tank sending unit and pump assembly into tank using new O-ring
  4. Place cam lock over assembly and lock by turning clockwise
  5. Install Fuel Tank
  6. Start engine and check fuel pipe connector for visual leaks
Oct 20, 2010 | 1994 Buick LeSabre
Replace a fuel pump on 2000 chevy cavalier
REMOVAL & INSTALLATION
(see Figures 1 and 2)
CAUTION The fuel injection system remains under pressure, even after the engine has been turned OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
To install:
Fig. 1: The module fuel sender assembly is mounted in the fuel tank
Fig. 2: Modular fuel pump component identification
Hope this help to solve your problem (remember comment and rated this).
Apr 25, 2010 | 2000 Chevrolet Cavalier
How do i replace the fuel filter on a 2000 Nissan Sentra
Fuel filter for SRDE20B15 engines (00-01) are in the tank mounted on top of the fuel pump inside the fuel assembly. Release fuel pressure by starting car and removing the fuel pump fuse, open fuel filler cap, remove rear seat, open fuel assembly cover by turning the screws clockwise, remove harness, remove fuel line quick connector carefully (if pressure was not relieved, gas will leak, make sure to release pressure completely), take out fuel assembly (watch out for fuel level sensor and temp sensor thingies). Pop top off the fuel assembly and pop fuel level sensor unit with screwdriver. Remove fuel pump harness connector, quick connectors. Pop top off completely, pop fuel filter+pump assembly out, remove fuel pump bracket on the bottom of it. Push fuel pump down from the top harness connector, Take out the rubber grommet (very important - car won't start) between fuel filter and fuel pump, put it into new fuel filter, and reverse all the steps to close it up.
Apr 23, 2010 | 2000 Nissan Sentra
Water has started pouring out from under my washer
Hello, you've indicated this problem only arrises during the rinse cycle, is that correct ? The leak doesn't occur during the wash cycle initial fill level ? I want to distinguish the difference because there has been a repair tip issued by whirlpool for the duet and sport washer's. This may be applicable to your machine. If it is indeed only during the rinse, the problem is within the door assembly. Specifically the glass and it's "seat" to the frame. Let me know, I'll watch for your reply. macmarkus :)
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need to know find and replace the fuel pump on my 1995 cavalier
This is what i was able to pull up for you to help you. please let me know if you need further asistance with your vehicle and I would be glad to assist you..
Please do not forget to rate and comment about your experience with fixya today.
Fuel System > Gasoline Fuel Injection System > Fuel Pump > Removal & Installation Removal & Installation
To install:
Jan 07, 2010 | 1995 Chevrolet Cavalier
Replace fuel pump for 2002 gmc sierra 2500
First...this is where the pump is (gas tank) on the engines listed:
Illustrating fuel pump and sending unit sensor (3) on 1999-2005 4.8L, 5.3L, 6.0L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • Negative battery cable
  3. Relieve the fuel system pressure.
  4. Drain the fuel tank.
  5. Remove or disconnect the following:
    • Fuel tank
WARNING Do not handle the fuel sender assembly by the fuel pipes. The amount of leverage generated by handling the fuel pipes could damage the joints.
  • Fuel sender assembly retaining ring using a fuel tank sending unit wrench. Remove the fuel sender assembly and the seal. Discard the seal.
  • Note the position of the fuel strainer on the fuel sender. Support the fuel sender assembly with one hand and grasp the strainer with the other hand. Pull the strainer off the fuel sender. Discard the strainer after inspection. Inspect the strainer. Replace a contaminated strainer and clean the fuel tank.
    • Fuel pump electrical connector
    • Electrical connector retaining clip from the fuel level sensor
    • Sensor electrical connector from under the fuel sender cover
    • Fuel level sensor retaining clip
  • Squeeze the locking tangs and remove the fuel level sensor.
  • Remove the fuel pressure sensor.
  • To install:
      • Fuel pressure sensor
      • Fuel level sensor
      • Sensor retaining clip
      • Electrical connector to the fuel level sensor
      • Electrical connector retaining clip to the fuel level sensor
      NOTE Always install a new fuel strainer when replacing the fuel tank fuel pump module.
      • New fuel strainer in the same position as noted during disassembly. Push the strainer on the bottom of the fuel sender until the strainer is fully seated.
      • New seal on the fuel tank
      NOTE The fuel pump strainer must be in a horizontal position when the fuel sender is installed in the tank. When installing the fuel sender assembly, assure that the fuel pump strainer does not block full travel of the float arm.
      • Fuel sender assembly into the fuel tank
      • Fuel tank. Install the fuel tank strap attaching bolts. Tighten the bolts to 30 ft. lbs. (40 Nm).
    2. Refill the fuel tank. Install the fuel filler cap. Connect the negative battery cable.
    3. Turn the ignition ON for 2 seconds.
    4. Turn the ignition OFF for 10 seconds.
    5. Turn the ignition ON.
    6. Inspect for fuel leaks
    Oct 25, 2009 | 2002 GMC Sierra 1500
    GE 24 in. Profile PDW9200J Built-in Dishwasher Logo
    46 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Garth Jackson
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
