Question about Troy-Bilt Troybilt Tomahawk I Drive Belt (w5l350) (1108544)
T bilt riding mower deck
Model # 13AN779G766 42 in cut. Need instruction how to remove deck. and add wheel kit to front of deck. I cannot find a free downloadable manual on-line.
Thanks!!
I think this is what you are looking for:
https://www.dixiesales.com/ipl/339/13an77tg766.pdf
Posted on Jul 10, 2010
I have a craftsman LT1000 model # 917-275351.It cuts crooked and I don't have an owners manual.How do I adjust it to cut evenly
2 ways to adjust deck level, the obvious is the ground wheels. The other is adjustment rods that hold the deck to the under side of the frame, usually 2 rods one on each side and maybe 1 in the front of deck/frame
Jun 13, 2014 | Craftsman Garden
Replace drive belt lt 1000
look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Oct 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro wheel horse rider recycler 8hp-25inch cut model#56132 how to remove mower deck
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual.
Apr 30, 2011 | Toro Garden
My deck is not level after removing it for blade sharpening. It was cutting level. Where does the anti sway bar connect? biazzio@yahoo,com
you need to go to the sears parts website, or the craftsman website, and get yourself an owners manual. these generally can be downloaded for free. in the manual there will be directions for leveling
the deck. a google search may take you to a fee site, so go to the sears sites first. the thing was made by AYP so you can google that too in case sears and craftsman do not have free downloads.
Apr 12, 2011 | Craftsman 26 Hp 54" Deck Yard Tractor
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
My lt1000 craftman tractor cuts uneven in the middle of the path. what can i do. need a manaul
You can download a manual from www.managemyhome.com for free. The manual will tell you how to adjust the deck.
Aug 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I install deck wheel kit?
check on line at craftsman for instruction.
Jul 16, 2009 | Garden
Craftsman LT1000, model 917.272059 - cutting deck misaligned
Go to www.managemyhome.com and download the manual. Make sure you type in the model # without the period (i.e. 917272059).
Apr 29, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Owners manual
Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
Components of a typical riding lawn mower. (click to enlarge)
It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
To remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
To adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Apr 12, 2009 | Garden
Troy-Bilt Troybilt Tomahawk I  Drive Belt (w5l350) (1108544) Logo
332 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
