Washer does not drain or go to Spin cycle - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that will help you with that...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 07, 2010
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Water not draining from washer. cannot open door. isnt there just a spin cycle i could go to instead of the entire wash cycle? i have already put it through 2 more cycles hoping the spin would drain...
Hi lauraeuschwa,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Kenmore HE2 Plus Front Load Washer
Washer will not spin in wash cycle
I have a Kenmore washer that will not spin or drain.
May 31, 2010 | GE WBSR3140DW Top Load Washer
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
