Question about Lucent PARTNER18 Corded Phone
I need to change my extension.
The line in my office has me as extension 11 and another office line is set up as extension 10. I need to change the line in my office to be 10 and default to zero.
  • 1 more comment
  • amessier May 07, 2010
    Thank you, but the front panel will not come off. Is there any way that I can make the change from the phone itself?
    I can see what you are talking about, but there is another partial plastic cover, with no screw, clamped over top of the box. I can't cannot remove that.
  • amessier May 13, 2010
    Thanks, I have it swapped now, and everything is working fine!
    President:
  • Lucent Master
  • 860 Answers
You can swap extensions 10 and 11 back at the phone cabinet. Remove the front cover(if there is one), depending on the type of partner system you have stations 10 &11 will either be in the center card(ACS) or in the 1st card on the left(partner and partner plus). Both ports should be marked but if not they are the first 2 ports. un-plug 11 and 10 and plug the cord previously in 11 into port 10 and vice versa.
Posted on May 07, 2010
  • 2 more comments
  • george  peters
    george peters May 07, 2010
    A little more info on the ports, you should see a separation of 2 or 3 ports first. Those are the lines going into the system. The next group of ports grouped with either 6 or 8 are the station ports. this is where 10 and 11 are located.
  • george  peters
    Unfortunately no, the only way is to change the port going to the phone. the only thing holding the cover on is a screw on the bottom center of the cover once removed the cover rotates up.
  • george  peters
    If the partial cover your talking about is reverse "L" shaped and about 16"x24" (about) then thats the cover that you lift up and out in an upward motion. sometimes some of the wiring can make the cover a little harder to lift but not too hard.
  • george  peters
    george peters May 13, 2010
    any luck?
How do you change the time on the Avaya phone 700340193
Partner ACS, any release
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
2. Press the left intercom 2 times
3. Enter # 103
4. Enter the correct time in 24 hr. format, for example:
* to set the time for 09:00 A.M., enter 0900
* to set the time for 04:45 P.M., enter 1645
5. Press feature, 0, 0
http://dstech1.com/changing-time-on-a-partner/
Nov 11, 2011 | Avaya 700340193 Corded Phone
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
When calls come into the office ext. 10 rings. It's the receptionist's desk. However ext. 29 rings too. How can I stop ext. 29 from ringing on all incoming calls?
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Oct 26, 2010 | AT&T Lucent MLS-12D Phone
Want to turn the ringer off unless receiving a transfer.
This feature determines how each outside line or pool assigned to an extension rings. You can specify Immediate Ring, Delayed Ring (telephone rings after a 20-second delay), or No Ring. Delayed Ring is useful for backup coverage on shared lines or pools, such as for secretaries who cover each other’s lines. No Ring is useful for all extensions except 10 when an operator answers all calls, or for telephones with no regular users, such as those in conference rooms. To change the way outside lines or pools ring at an extension:
To change the way outside lines or pools ring at an extension: 1 Press "Feature" , "00", "System Program ", "Central Tel Program" at extension 10 or 11.
2 Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons show the current Line Ringing settings for all lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green light next to that button is off.) The following ringing options can be shown by the green light next to the line or pool button: • Immediate Ring — on steady • Delayed Ring — flashes slowly • No Ring — flutters quickly • Immediate Ring is the factory setting for lines; No Ring is the factory setting for pools.
3 Press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
4 Continue programming, or exit programming mode.
Aug 06, 2009 | AT&T Lucent MLS-12D Phone
Call forward
Feature 11 -enter your phone number to forward to.
Make sure #323 in the programing on ext 10 or 11 is set to 1 for your extension.
Mar 18, 2009 | Lucent PARTNER18 Corded Phone
Incoming calls to office cause all phones to ring in classrooms
Press the right hand intercom once. The display should say Centralized Programming.
Hope that helps
Dec 02, 2008 | Lucent PARTNER18 Corded Phone
Programing Ayava partner - 18d Phone
From extension 10 or 11
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
then the order you want the lines to get picked up (if you want to grab line 4 then 3 then 2 then 1, upon going offhook, press "** line 4 line 3 line 2 line 1)
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
Nov 25, 2008 | Avaya Corded Phone avaparp18d
When receiver is picked up, it opens the wrong line
. Changing line selection on a Partner system is done on either ext 10 or 11.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Hope that helps
Nov 23, 2008 | Lucent PARTNER18 Corded Phone
Change the time on my Avaya Partner Phone
You can not do phone system programming from anything EXCEPT Extensions 10 or 11.
http://www.telemanuals.com/forum/index.php?topic=2.0
Nov 17, 2008 | Avaya 700340193 Corded Phone
Change te number of rings
I need to change how many rings it takes my system to answer . It is set for attendant , I need it to answer after 5 rings . I need this changed because I now have a answering service that is set up though my phone provider verizon to call forward after 4 rings Lucent partner 18d
Jul 18, 2008 | Lucent PARTNER18 Corded Phone
Lucent PARTNER18 Corded Phone Logo
196 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
tfelton3
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
