Question about Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac
Remote says OUT OF RANGE when i try to arm it.
I recentl bought the autopage alarm with remote start. i bought it in one city and now i work about 2 hrs away. It tells me that it is "out of range" everytime i try to arm my system. How do i fix this problem? Thank you.
    New Friend:
  • 103 Answers
Reprogram the remotes using this procedure:
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
Posted on Aug 13, 2010
  • Jason Ewing Aug 13, 2010
    if you have the motorcycle alarm, you need to press the valet switch 3 times, not 2. Sorry about that. same procedure though.
ALARM INSTRALL WITHOUT REMOTE START
You need to install the power wire and the ignition wire on the alarm . Most alarms draw power from the thick power wire some have a small power wire and Small ignition wire input that needs to be hooked up also. Only ignition one needs to be hooked up.
May 04, 2014 | C3RS6652W
How do I reserve battery life on my autopage alarm key pad model XT-73LCD
If you put remote in your pocket or your purse make sure it doesn't push on any buttons!
Mar 30, 2014 | C3RS915 SST Remote Car Start Vehicle...
My alarm wont beep and the remote starter stop working
Check the units fuse if that's ok you may need to replace the alarm devise...
Dec 02, 2013 | C3RS603 2Channel Remote Start Module with...
My autopage remote wont start
RF425 is an alarm only, it does not start the vehicle.
Aug 23, 2011 | AutoPage RF425 LCD (RF425LCD RF425 LCD)...
Somehow buttons seem to have been pressed on my remote and now there are 3 "z"'s that have appeared on the remote and I have no idea how to get rid of it. My remote now doesn't make a...
Turn ignition on, hold the red valet switch down for 2 seconds. Then turn ignition off. Your system is in VALET mode.
The remote start and alarm system will not work when in valet.
Aug 06, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
My autopage rs 727 lcd is not starting in remote start, it is only cranking
what kind of vehicle? it is most likely a transponder or theft system bypass problem, since it is trying to crank.
Feb 12, 2011 | C3RS727LCD 4Channel Alarm with Remote Car...
Why does the alarm in my car go off when I try to start it with the remote car starter?
If this is the vehicle's factory alarm that is being triggered then your factory alarm must be disarmed prior to the remote starter sequence. The Autopage unit has a factory disarm wire available for this purpose. When the alarm triggers again try turning the key in the driver's door to see if there is a factory disarm wire available in the vehicle or if the factory alarm is RF disarm only. If it is the after market alarm that is being triggered then you made need to decrease the sensitivity.
Nov 23, 2010 | C3RS727LCD 4Channel Alarm with Remote Car...
I have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
Jul 16, 2010 | C3RS603 2Channel Remote Start Module with...
Is it hard to install a remote start /alarm in a 2003 mazda mpv autopage c3- rs730
make sure you get one to fit that year make and modle and yes it takes some mechanical know how.
Feb 02, 2010 | Megatronix - TW71 - 5 Button 2 Way LCD...
Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac Logo
1,194 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
