Question about West Bend 13500 Coffee Maker
Use of warm water
Good day! I just want to know if it possible that I can use warm water to boil in west bend coffee pot so that the time of boiling will be faster compare to cold water.
  • 242 Answers
Warm water is said to contain more impurities than cold water, like lead. Warm water takes more lead from your home plumbing, than cold water.
So it's not advised to use warm water for boiling...
Posted on Mar 27, 2008
6ya staff
SOURCE:
Churchs bunn. Vps 04275-0013 started heating water till steam comes out fill hole. Causing water to drip everywhere....thinking a thermostate is not opening causing steam
Over Boiling or constant heating of tank water is an indication of a shorted thermostat (or out of calibration). Call your vendor for service. (especially if this equipment is on loan.)
*** the following is for information only. Repairs should be performed by a qualified Bunn Tech. ***
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
PS; There is a slight chance that your thermostat is set too high. There is a dial on the thermostat that can be turned counter clockwise to lower the temperature of the brewing water. Water should be about 190-205 F for coffee. Tea drinkers want 210 F which is too close to boiling point of water. If your in the mountains (+2000 feet) then the boiling temp will lower. Was it possible the brewer came from a low (sea level) location and moved to higher altitude? Then the setting is off and must be set lower (a fine adjustment). But note that if your on the top of a high mountain (like Haleakala, Hawaii) then it has to be set a lot lower and you will only get luke warm brews at 9,000 feet!. Adjust the knob clockwise to get it to boil. Then back it off counter-clockwise a bit till it stops boiling. Make another brew to check if the reheat comes to a boil but stops after a minute or so. It should not boil on longer than 2-3 mins. Back it off a bit more if it does. Brew again to check. If none of this works then you will need to replace the thermostat. If your at a really HIGH altitude location, then you will need a specially adapted high altitude brewer. Call your coffee vendor for advice.
Feb 16, 2018 | Coffee Makers & Espresso Machines
Do you have to boil water in something else first
No, it's an electric coffee pot, it heats the water and makes the coffee simultaneously.
May 31, 2014 | West Bend (58036) 36-Cup Coffee Maker
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    On the dial there is off, low, high and auto. What does the auto do? If I select auto is there a timer on it that shuts the pot down after a time? Is fo what is the time.
    There is no timer -- with the dial set to auto, a thermostat opens and closes turning the heating element(s) on and off to keep the pot at a fairly constant temperature. The high setting can continually boil the contents, and can burn the food if not stirred. The low setting is for keeping contents warm.
    I'd use "auto", if the pot is not going to be monitored.
    Charlie
    Mar 27, 2011 | West Bend Crock Pots & Slow Cookers
    West Bend Lifetime Stove Top Coffee Maker This is a nice heavy stainless steel coffee maker, probably from the 50s or 60s. It has four parts; a carafe that sits on the stove, a piece that fits on that with...
    Not to sound like a knw it all, but we have a pot just like this. You have to boil the water in a seperate kettle and pour it in the pot. This is a drip pot, not a perculator. It will make the best coffe you've ever had.
    Jun 20, 2009 | Coffee Makers & Espresso Machines
    Strong plastic odor in West Bend coffeemaker
    oh yes. This must be a new machine. I would recommend pouring and draining boiling water in the maker several times. You can also use vinegar, but again it has to be rinsed and refilled and rinsed again with boiling hot water.
    Jun 11, 2009 | West Bend 56860 10-Cup Coffee Maker
    Bunn Coffee machine only makes 1/2 pot
    What's happening is that it isn't leaking, it's boiling over. You need to turn down the thermostat under the top lid. Also, before you brew coffee, add water to the tank and let it pour into an empty pot. Once it stops brewing, let it heat up for a few minutes then make your pot of coffee.
    Jan 02, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
    Warming plate boils coffee.
    Make sure you are using the type of commercial coffee pot like the one in the picture. They don't have to have to be plastic with the metal bottom, they can be all glass. The commercial pots are heavy duty and usually disperse the heat well.
    If you are using commercial pots the only solution without replacing the warmers is to put three pennies on the warmer and to put the pot on top of them. The pennies will get hot so don't forget and grab them but the pennies help to move the pot just a little way away from the direct heat.
    Feb 08, 2008 | Bunn VPR Coffee Maker
    West Bend 36 cup coffee maker amounts
    It's a percolator. Use about 1 heaping teaspoon of coffee per cup. Each coffee pot is different. You will have to adjust the amount of coffee for what you like.
    Dec 03, 2007 | West Bend (58036) 36-Cup Coffee Maker
    West Bend 13500 Coffee Maker Logo
    176 people viewed this question
    Top West Bend Coffee Makers & Espresso Machines Experts
    Pierre Laplante
    Ray Murphy
    Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
