Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Philips 37pf7320a/37 picture issues.
Hello there. I have a philips flap panel LCD and when I left for work this morning the TV worked fine, came home about 8pm and went to turn on the set and green light came on but no picture. I have cycled thru all of my connections and can hear sound from every single input, (Xbox360, PS3, Cablebox) but they all show no picture. I dont have any blinking red lights and even tried the firmware update. Powered tv down and inserted the memorystick then powered up, sound cut off for a moment and saw green light on memory device flicker as if it were communicating with TV. Powered down after 10 min then powered back up and still only sound. If you have any idea what could possibly be the problem please help me out. Thank you for taking the time to read this and have a great day.
  • 138 Answers
The problem is the small signal board that is the video processor.
Posted on Aug 20, 2008
SOURCE:
The volume controls on both my remote and my Philips flat HDTV 37PF7320A 37." How do I fix it?
Read your Philips setup info that came with your tv very carefully and also if applicable read your cable box setup info very carefully then set every thing up like it says also check tv audio menu and make sure the audio is set to on
Sep 13, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
Ambilight Issue
Never do anything to this set now. Contact the authorized service center for Philips. Gopakumar Gopalan Google
Feb 25, 2014 | Philips 42PFL7332D 42 in. Flat Panel LCD...
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Tv is 3 1/2 years old, worked fine this morning, then it started making a funny humming sound and the left side of the tv went dim. Could it be a bulb?
It could be the invertor that runs the maize of lamps on the left side.
If there are spares it shouldn't be too costly.
Hope that helps.
Jan 02, 2011 | Vizio 42 in. LCD TV
No picture on left side of screen and bad picture on right side.
Hello:
Have the Digital board and logic board replaced. the most common problem will be the logic board assembly. Altho the Digital board can also cause this problem. Try taking off the back and making sure the LVDS Cable is connected tightly to the logic board assembly and the panel, (Scrn), The LVDS Cable will look like a small wire harness with two metal clips on each end make sure it is secure, try disconnecting it and reconnecting it again.
Jan 13, 2010 | Philips Magnavox 42MF521D/37 Television
I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Aug 13, 2009 | Televison & Video
I have a philips 42PF9641D/10 and the ambilight on the left side will not come on (lcd tv) any ideas? On turning on the TV both ambilights came on then the left side went off after about a minute!
probably you got a processing unit problem, which makes your tv stopping recognizing the screen information .
you should try resetting all factory default settings, if this doesn't work, you will have to take the TV to an assistance center .
Jul 30, 2009 | Philips 42PF9631D 42 in. Plasma Television
37" Philips LCD sound but no picture
Check the inverter on the sides of the TV. This sounds like the inverter is going bad and that's the reason why you have sound but not picture.
Jun 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
330 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
