Question about Sharp Televison & Video
Sometimes when I turn on my TV, the sound does not come on. If I turn it back off and wait until a click is heard, the sound does come on. What's up?
  • 3,037 Answers
The tv sounds like it might have a cold solder joint and the joint needs to warm up before the audio circuitry works. Depending on the age of the tv, it probably isn't worth fixing unless you have electronic expertise since it still works when you turn it on a second time. As long as it still works, I wouldn't worry about it for now. If you run the tv for a while and then turn it off for 5-10, I bet the audio works right away, if so, then it is just the problem I described and the easy solution is just to let it warm up. The click is probably that cold joint getting a connection.
Let me know how this works out for you.
Benjamin
Posted on May 07, 2010
Clicking sound when you turn the tv on but won't work until a few minutes sometimes longer .
The clicking sound is an indication that the power supply is trying to start but is failing
Apr 16, 2013 | Televison & Video
1992 Buick Park Avenue ignition switch
remove extra keys from key ring. if helps replace ignition switch . I never heard of the ignition making trunk pop but there s always a first.
Sep 06, 2017 | 1992 Buick Park Avenue
Tv won't turn on. blinking red light in lower left corner
unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
Feb 14, 2010 | Panasonic TC-32LX700 Television
My tv turns off by itself and makes a clicking noise
Most likely it has some bad capacitors in the power supply. Flat--panel sets are VERY hard on capacitors, due to the fact that the "rising heat' from the set "cooks" the caps and they fail VERY early.
Oct 12, 2009 | Samsung HP-T4234 TV
HL-R4266W shuts down and a faint clicking sound can be heard
I believe I read somewhere that when you open the back cover over the lamp, there is a special little black switch that needs to be in the up position when you put the cover back on, or the TV can shut itself off randomly.
Aug 16, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
TV turns off by itself
Thus the line connected to a surge protector or some kind of line protector. This can be consider.
Or if this is a crt type tv. This could be a fault on high voltage section. Horizontal output transistor or flyback. But check also for loose connection/solder crack. That clicking sound may be the relay in action.
hope i give some correct input.
Apr 23, 2009 | Samsung PCL5415R TV
I have been playing my playstation 3 on a regular Hd tv and it worked fine but now it wont connect to my Protron (HDMI) tv with my HDMI cable.
you have to reset the video setting and it will work again Hdmi is different on each tv so you have set this up again ok let's do this with the unit off turn the main switch on the back of the unit connect your Hdmi cable to your tv now place your finger on the front on/off switch keep your finger there ok now turn the mainswitch on the back of the unit the playstation turns on but don't remove your finget yet wait about 4 seconds or until your heard another bip (not the one when the playstation turns on) once you heard this bip remove your finger before the playstation turns off if you let it turn off try again all of this but if you remove your finger on time just wait few more seconds and bingo you have picture again using Hdmi
Mar 10, 2009 | Sony PlayStation® 3 (80GB) Console
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Tv turnitself off and on at will
This sounds like a power supply problem possibly a bad capacitor
Jun 19, 2006 | Quasar SP-2023D 20" TV
Televison & Video Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
