Question about Samsung SGH-E251 Mobile Phone - Black
Keypad,on off lcd
My motorola mobile keypad doesn't function it just turn on but not fuctioning,so on to my nokia 6500 the lcd show up but after putting my pincode it goes off.
    Guru:
  • 257 Answers
For the samsung you are to remove the casing and below the casing where we have those button touching the board with a white nylon on it try oning the phone without the casing and be pressing your keypad on the nylon with a pencil or pen to get where the fault is from . if is not pressing down at all then the nylon must be change because is the one the keypad will press and the nylon will be sitted down and up.
check that out.
kindly rate this solution..
Posted on May 07, 2010
  • Temidayo Abraham
    Temidayo Abraham May 07, 2010
    For the Nokia you are to Flash the phone .. the problem is a sofware problem which means the phone has been affected by virus . so flash your phone with a design phone flashing software. then your phone will be ok
How to turn up volume on handheld?
It is best to contact Motorola Solutions.
http://www.motorolasolutions.com/support
Mark
Motorola Mobility Support
Aug 18, 2014 | Motorola MC9190-G Handheld Mobile Computer
Can't turn on nokia 6500
Give your mobile for service. The problem will be solved.
May 29, 2012 | Nokia DC-6 Vehicle Car Charger for Nokia...
The red key to switch on the mobile doesnt work so how to switch on my mobile
You particular phone is quite sensitive model
there are three possible reasons,
1::: the flex cable (it is a ribbon that connects the upper face to the lower one) might be damged or a line is cut
2::: the Keypad IC driver is damaged(it is the ic which controls the keypad functions)
3::: the keypad membrane might have accumulated dust and other debris(clening is required)
all of the three cant be performed by the user alone, thus, i suggest you bring it to a technician, slide phone are quite sensitive, being it having a flex cable, so no user can perform this without the proper training and tools to do so.
Aug 17, 2010 | Nokia 6500 Slide Cellular Phone
How to get restriction code for nokia 6500 slide locked at 3 mobile UK?I just need to open line so as to use any sim card.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#. hope it'll help you. or else folow this methodTo unlock your mobile phone, you'll need the following information: * Your mobile phone number
* The network (and country) to which the phone is locked
* The manufacturer and model number
* The phone's IMEI number. This is a 15 digit serial number, which you can find by typing *#06# on your phone's keypad.after this follow the link below to download software to remove sim restrictiond.(plz vote me)
mehttp://www.ziddu.com/download/4281464/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip.html
Mar 31, 2010 | Nokia 6500 Slide Cellular Phone
How do i change the housing on my 6500 slide mobile
You need a T5 screwdriver and a new housing... Use an Original housing, copies dont usually fit right... 1, Remove Back cover and Battery. 2, Remove 4 T5 screws at the back of the phone, run your fingernail/opening tool around the housing and it should come away a little, dont pull it apart as there are 2 ribbons one for the Screen the other for the keypad. 3, Turn the phone over and run your fingernail under the keypad. 4, Carefully take the bottom half away with the phones PCB still in the bottom housing, using a flat screwdriver carefully lift off the two Ribbons 5, You can then remove the keypad from the top part of the phone, this is stuck on by double sided tape pull downwards, there are 2 spring loaded pieces on each side. 6, Remove the 4 T5 screws, 2 under where the Keypad was and 2 at the top 7, Again using your fingernail or a opening tool run around the edge and the screen part should come apart, dont damage the ribbon You now have the phone apart take out the bits and change what you like :)
Jun 10, 2009 | Nokia 6500 Slide Cellular Phone
Nokia 6500 slide keypad problem and replacement off ice
Hi ,
you can go to the nearest mobile hardware point and checkout the mobile . they will repair. so any kind of problem then you can mail me.(susa.asha@gmail.com)
Mar 29, 2009 | Nokia 6500 Slide Cellular Phone
there are 2 things maybe possible to solve that problem, it maybe the source of problem is the  KEYPAD board or the FLEX,, you must refer it to the technician and check the malfunction of keypad.,
Samsung SGH-E251 Mobile Phone - Black Logo
69 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
