Question about Microsoft Windows 2000 Professional for PC
Windows 2000 o.s
I loaded windows 2000 o.s in my P.C with service pack 4. With this empty O.S it occupied 2.45 gb. So, now iam not able to load big size softwares. What can be thee problem.
  • Anonymous May 11, 2010
    That's about the right size for a Windows 2000 install, believe it or not. With the standard hard drive being 60gb+ nowadays. you are probably in need of an upgrade. Unless I'm missing something here. What size is your current hard disk?
  • darryl coueslant May 11, 2010
    How big is the harddrive? Is there a partition on it?
    Sergeant:
    Champion:
  • 329 Answers
I suggest to check your Hard Drive Capacity. make sure that there is enough space for your application..
Posted on Mar 27, 2008
SOURCE:
Western Digital 2500aajb hard drive not reconized by windows 2000. I can see it in the bios but not in windows. Thanks so much.
Make sure you have the latest service pack for Windows 2000 - this fix will NOT work on service pack 2 or earlier.
The reason you cannot see the drive right is that 2000 doesn't have big LBA enabled, and thus has a 137GB drive size limit.
To enable 48-bit LBA large-disk support in the registry:
1.Start Registry Editor (Regedt32.exe).
2.Locate and then click the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Atapi\Parameters
3.In the Edit menu, click Add Value, and then add the following registry value:
Value name: EnableBigLba
Data type: REG_DWORD
Value data: 0x1
4. Quit Registry Editor.
You should now reboot, and then you should be able to use your drive.
Mar 27, 2011 | Western Digital WD2500AAJB 250 GB EIDE...
Changing windows 4 to windows 2000 xp
First off, there is a big difference between windows 2000 and xp.
She needs her windows 2000 install disks and to re-install windows. Then she needs to install her service packs onto it. Either that or upgrade to windows xp. Id suggest she upgrade if she has decent hardware(memory, cpu and hard drive space)
There is no shortcut or work around unless you want to start using pirated stuff, which is probably not a good idea since most of that stuff is just an avenue for viruses and backdoor programs.
Mar 09, 2010 | Microsoft Windows XP Professional
Original "XP-Professional Disk" loaded - Will NOT accept svpk
Hi there.
When it get to the point where it cannot install the service packs, if it gives you an option to skip the files then do that and let XP install as usual, when its installed perform a Microsoft update and update the machine, this will no doubt take hours because if the disk is 4 years old it will want service packs 2 and 3 installing so make sure you set the computer to never shut down or go to sleep.
Good luck
Jun 11, 2009 | Microsoft Windows XP Professional With...
Problem loading XP Serve Pack 2 in Gigabyte 8I845GVM-RZ
I know this may sound mundane, but did you load the correct set of windows drivers for the Intel 845 chipset? I mistakenly loaded the Home drivers onto a unit I tried to install Pro on and I got all sorts of errors.
Mar 26, 2009 | Gigabyte GA-8I845GVM-RZ Motherboard
GTA San Andreas not loading
Uninstall and then re-install and you should be fine. just backup your save files first.
Mar 16, 2009 | Rockstar Games Grand Theft Auto: San...
Sound solution plz
goto control panel switch to classic view , double click add remove programs , then when the list comes up look for service pack2 and remove , then restart computer
Oct 25, 2008 | ASUS P5VD2-MX SE Motherboard
Loding problem
trust me on this... 1 gb is not enough to have a fast startup with vista... i've 2gb and the vista occupies 45% i.e. 900mb without running any application.... this is condition after disabling some graphics elements...
Mar 04, 2008 | Microsoft Windows Vista Ultimate Edition
Motherboard upgrade??
Dear kaname,
Your computer can support Windows XP, which has better hardware support and compatibility with the 2003 Office suit. XP also updates your hardware automatically once you are on the internet. You might want to try this.
Keep in mind that the older the Operating System, the harder it is for Office suites to compat. Newer Operating systems have better support for your computing. If you don't have HDD problems, the BIOS should not prevent you from loading SP2 for Win2000.
Conclusion:
1. The SP2 Source Disk may have a problem
2. The Win 2000 you have already loaded may be missing components, preventing the SP2 to load.
2. Notton Antivirus versions and the 2003 office both reject Win 2000. They just don't like it; it's getting too old.
Get with it, Kaname!!!!
Feb 27, 2008 | A-Trend ATC 5220 (ATC-5220) Motherboard
Microsoft Windows 2000 Professional for PC Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
