Question about Brother CS-6000
Bobbin holder popped out and I cannot figure how to get it back in
    Genius:
  • 1,116 Answers
Go to the maintenance section of the manual for cleaning instructions and this will show you how to remove and replace the bobbin case or shuttle for your machine.
If you do not have a manual, you can view or download (free) at the Brother website.
Hint - for all machines, turn off the power and then raise the needle to it's at highest position and this will align the shuttle to the proper position.
Posted on May 07, 2010
My bobbin holder flew out of my sewing machine and I can't get it to pop back in kenmore model 16524000
THE BOBBIN CARRIER IS WHAT FLEW OUT. THIS IS PUT IN BY ROTATING YOUR HAND WHEEL SO THE NEEDLE IS AT IT'S HIGHEST POINT. THEY'RE IS A SPRING THAT HOLDS THE CARRIER DOWN IN THE MIDDLE APPROXIMATELY. IT IS A LITTLE PIECE OF METAL BUT REALLY IS A SPRING. AS YOU PUT IT IN YOU WILL NEED TO PULL UP ON IT A LITTLE IN ORDER TO SLIDE IT IN. BEFORE YOU DO GO AHEAD AND CLEAN THE RACE THE CARRIER LIES ON AND PUT A DROP OF SEWING MACHINE OIL ON IT.
Nov 13, 2014 | Sewing Machines
How to place bobbin holder back into machine
the bobbin case probably needs to be replaced and the
hook and hook race may need to be check to see if something
is wrong with them.
Feb 06, 2013 | Elna Heirloom Edition 6005
Need a blow up diagram of the timing parts for Shark Intelli-Sew Euro-Pro Model 9110.
I had a timing problem, I believe, and fixed it. But its not yet perfect.....What happened was the top thread was not being caught by the bobbin holder. So when I "sewed", there were no stitches. When I watched the bobbin through the window, the bobbin didnt turn, and thread didnt whiz around the bobbin holder as it should with each stitch. I even made a video to see if there was a timing problem...the needle went down well before the bobbin holder "thread catcher hook" arrived to catch the loop. So I took off the plate underneath the bobbin holder, and adjusted the timing. When you do that you will see a cogwheel that rotates as the bobbin holder rotates. Three alan wrench screws hold it tight to the axle that rotates with the handwheel/footplate. I loosened the alan wrench screws, and then did the following. Hold the needle holder so it doesnt move, and at the same time turn the hand wheel a little. This adjusts the timing of the needle relative to the bobbin turning. then plug the machine in, and see if the bobbin wheel is now catching the thread. Keep adjusting until it does. Then tighten things back up, and VOILA! Im not sure this is the best way to adjust the timing, but it works. My machine went from no stitches at all, to sewing nicely. Its not yet perfect, as it jams every now and then. But that may be because the timing is still a little off, or because the thread is bad, or the tension of the thread is not quite right......working on that still.......
Sep 11, 2012 | Sewing Machines
Singer 9410 Bobbin Repair
it sound like the machine needs to be serviced by a sewing machine repair tech
Jan 28, 2012 | Singer Sewing Machines
I threaded it all right i have cheacked it many times but the thread in the bobbin keeps getting jammed
Many causes for this problem. Most common are;
  1. Top thread not inserted correctly.(must keep thread tight.)
  2. Debris and loose thread around the bobbin cage. All it takes is a tiny piece of thread in the right place.
  3. Bobbin inserted backwards in the "bobbin holder". When installed correctly, There is some resistance when you pull on the thread, but the bobbin will spin without trying to pop out of the "bobbin holder".
Oct 29, 2010 | Brother XL-5500 Mechanical Sewing Machine
Shirring fabric?
Drop the bobbin with the elastic in the holder without feeding it through the holder, and enlarge the stitch length,
Mar 29, 2009 | Brother XR7700
I took apart my bobbin case, plate andbobbin holder. I can
I had the same problem and can't find my Owner's Manual. I found the answer on-line. Hopefully, you have the same type of bobbin casing. To get the answer, go to www.startsewing.co.uk and choose "How to thread a Sewing Machine". If you have the same type of bobbin casing, you should be able to figure out the proper placement of the parts by looking at the one in the demonstration. I am thrilled (!) and hope this works for you, too.
Jan 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
I removed the positiong plate
I removed the posiotioning Plate(A). Singer Inspiration 4205. How can I get it back in?
Sep 23, 2008 | Singer Inspiration 4210 Mechanical Sewing...
Bobbin holder pops out all the time.
We just had the same problem recently with our machine, it turned out that the bobbin was in backwards(rotating the wrong direction). Try flipping the bobbin around and see if it fixes the problem.
Sep 19, 2006 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Brother CS-6000 Logo
194 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
