Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
DWl-2100ap Power light keeps blinking
Blinking is 10sec apart - during which time it keeps losing contact with PC
Reset button doesn't work
  • chimmy rai
    chimmy rai Aug 02, 2017
    mine continously blinks.tried reseting to factory defaults but cannot access webinterface through 192.168.0.50
    urgent help needed?
Benimur
  • 6966 Answers
SOURCE: Dlink DWL-2100Ap
Hi, Most routers/AP of this type don't really need/have an installation software. Their configuration is done thru a webinterface which opens in your browser. If you have connected your PC via a lan cable to the router, then configuration should relatively be easy. The most that you need to do is to verify that your PC is set to Auto Obtain IP Settings Automatically, or if you have a your own network adds, you must change it first to match the routers. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Posted on Sep 14, 2007
  • 54 Answers
SOURCE: DWL 2700 AP wrong firmware install
hi...
since you upgraded a different firmware try updating the firmware again with the correct firmware if it works fine if it doesnot then the router had gone bad,,
and for GeminiBS reset the router to the factory default since the firmware was not done in a proper manner may be it had interruptions..once the hard reset is done the computer is restored back to the default so that you can use the device..
vedhick
Posted on Feb 16, 2009
rahul26485
  • 611 Answers
SOURCE: how to connect dlink dwl 3200AP with dlink dwl
make a repaeter mode
and ip would me same range
Posted on Mar 03, 2009
  • 12 Answers
SOURCE: dwl 2100ap
This is the power cycle of death. No way to recover at this point. Send in for repair.
Posted on May 12, 2009
tommya300
  • 724 Answers
SOURCE: my dwl 2100ap power led blinks about 4 times then
see if the reset connection button is wedged it is like it is in constant reset
Posted on Jul 31, 2009
Dwl-2100ap d-link wireless access point. I want to reset my device, I have forgotten my PWD and Log name.
First, to reset the router to factory default setting, press and hold the reset button for few seconds (It is at the back of the router on the right hand side to the DC Power Jack). The LEDs will then blink and the routers factory settings wouls be restored.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 10, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Hi, My d-link dl-604 suddenly stopped working. When I plug it in, only the power led and #4 lights are up. None of the other leds are responding nor the internet is not working as well. Please help. Thanks
The following reset procedure will completely restore the default settings on your D-Linkmag-glass_10x10.gif device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
Hope this helps! Give me thumbs please!
Aug 23, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Dwl-2100ap will not update firmware
1) Reset do default the device (rear reset button)
2) Set your PC a IP like 192.168.0.xxx (defaul IP address for DWL-2100 AP is 192.168.0.50)
3) Connecto via browser to 192.168.0.50, defaul login
To set IP address on you PC: goto LAN devices, click properties on your LAN, scroll down and selectInternet Protocol (TCP/IP), click properties, click set followingIP address:
IP: 192.168.0.1
Subnet: 255.255.255.0
Default Gateway: 192.168.0.50
If this information can help you, please rate me ;)
Aug 31, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Upon powering up 2100ap the power led in continuously blinking and i can not get ip address to open web page
1) Make sure that reset button blocked in "pressed" position, this can perfom a constant reset
2) Try to reset to default settings.
-Locate Reset button on the back of the device.
-Use a paper clip to press the Reset button.
-Hold for about 5 seconds and then release.
-After reboot the device it will reseted to default settings.
Jun 06, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
Can't access D-link DI-614+ as admin
Direct from the D-Link FAQ's
This reset procedure applies to the following devices:
DI-704  DI-704P  DI-713  DI-713P  DI-714P+  DI-804HV  DI-808HV
  • Step 1 Power the unit off by unplugging its power adapter.
  • Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
  • Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
  • Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
  • Step 1 Locate the reset pinhole on the back of the unit.
  • Step 2 With the unit powered on, press and hold the Reset button.
  • Step 3 Hold the Reset button for about 10 seconds.
  • Step 4 Release the Reset button.
  • Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
  • Step 6 The device is now at factory defaults.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | D-Link AirPlus DI-614+ Wireless Router
Power on and off
it is not the power, but it is searching for a signal to connect to via cable. make sure the cable is connected correctly
Jan 06, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Forgot my password
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-624M, DI-624S, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP. Step 1 Locate the reset pinhole on the back of the unit. Step 2 With the unit powered on, press and hold the Reset button. Step 3 Hold the Reset button for about 10 seconds. Step 4 Release the Reset button. Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting. Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Forgot my password
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
2,013 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
