Question about Canon Rebel XT / EOS 350D Digital Camera
Won't turn on with memory card installed. have had it for 5 years, no problems. now, when I change the card, it won't turn on. it WILL turn on WITHOUT a card, but not with one. any ideas?
  • Canon Master
  • 4,738 Answers
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
Posted on May 07, 2010
I have a silver slim ps2 model number SCPH-77001. Everytime I play a ps1 game on it (which it has no problems with) it wont read my ps1 memory card. I've tried it on both slots, tried 4-5 other ps1...
You shouldnt have too. I think I know the problem. Turn on your ps2 without a game in it and it would take you to the home screen. After that go to browser with your ps1 memory card and select it. And then it should give you an option to format it. Hope this helps
Dec 06, 2012 | Video Game Consoles & Games
My memory card is not working
Memory cards, also called memory sticks or MS cards, can create problems with a computer. Sometimes, a computer will not read the card or errors cause problems when removing files from the card to put them onto the computer.
Problems range from a virus on the memory card to inappropriate software on the computer. Fixing the problem partly depends on the cause of the problem, but making the card work is simple and takes only a few minutes.
Scan for viruses. Some viruses or worms infect MS cards.
A computer that suspects a virus might interfere with the memory card as a result.
Look for viruses or problems with the anti-virus software that won't allow the memory card to open. If a virus if found, remove the virus through the anti-virus software before opening the memory card.
Check that the computer has the appropriate software installed to read the card.
Some MS cards or memory sticks might require more updated software or specific software that is not on the computer.
If the software is installed, look for current updates and download any updates to determine if the problem is old software.
Open the control panel.
Click on "Add New Hardware" and see if it is available.
If the hardware for the memory card is not installed on the computer, this will allow installation.
Once installed, the card should read.
If the memory card is not showing up, the problem is often damage to the card, which prevents reading the card. If the card is damaged, it must be replaced.
Use an adapter.
Some memory cards are not designed for reading in a computer directly and require the appropriate adapter.
The adapter changes the data to the appropriate system for the computer to read it.
Hope this helps
Nov 16, 2012 | Electronics - Others
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
My Kodak EasyShare C180 10.2MP Digital Camera is less than a year old and suddenly won't turn on. I thought the batteries were dead so I replaced them...twice...and tried changing the direction around...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 06, 2011 | Kodak EasyShare C180 Digital Camera
I have a Olympus X-560WP & when I turned it on, the screen appears with a P in the left corner, a red flash symbol in the right corner & it says on the bottom +1.0 1/30 F3.7. It isn't allowing me...
You can try to reset it by:
1. Turn it off,
2. Remove battery (the big one)
3. Remove the little round battery (which supply power to rom chip)
4. Remove memory card.
5. Leave it for 15 minutes.
6. Put everything back, except the memory card
7. Turn the camera on.
8. When it proms to install memory card, turn it off and install a memory card.
Mar 20, 2011 | Olympus Cameras
Both memory cards show "THIS
Are both cards 4GB or larger SDHC cards, and is your camera more than a few years old? There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 29, 2010 | Cameras
Can't get the information stored on my memory chip to download on my phone . The info stores on the memory but won;t install on the phone so i could enjoy music
I have this phone also. You go to settings .. Memory ... and in the memory menu you have to change default storage to memory card instead of the phone. I had the same problem : (
May 12, 2010 | LG Neon GT365 Cell Phone
My Photosmart E327 won't switch on.
Resetting the camera
If your camera does not respond when you press any
buttons, try resetting the camera as follows:
1. Turn off the camera.
2. If you have an optional memory card installed, remove it.
(Although removing an optional memory card is not
necessary for performing the reset, it eliminates the
memory card as a possible cause of the problem.)
3. Remove the batteries from the camera for 5 to 10
seconds.
4. Reinsert the batteries and close the Battery/Memory card
door.
5. After verifying that the camera works without an optional
memory card, turn off the camera and reinsert the card if
you have one.
Mar 03, 2009 | HP Photosmart E327 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
104 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
