Question about Sony KV-27V42 27" TV
Sony ctv 4 times blink model kv-tg21m70 - Sony KV-27V42 27" TV
SOURCE: sony tv kv-36fs120 will not turn on
Don't bother taking it to a repairman. The cost would be over $400 to fix. My Sony wasn't even three years old which is maddening since it cost $900+. I noticed another woman wrote in about the same problem and she was also quoted a repair of $400+. I didn't buy another Sony, that's for sure!
Posted on Dec 13, 2007
SOURCE: Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Posted on May 09, 2008
  • 4234 Answers
SOURCE: SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Posted on Oct 01, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
sams_trix
  • 93 Answers
SOURCE: Sony KV-34HS420 shuts of and stand-by light blinks
blinking 7 times after shutdown and after 3 sec repeats the same number of blinks.possible cause is over voltage at horizontal deflection circuit,or over voltage at power supply, or high voltage leak at FBT,or FBT itself is defective.open resistor related to ABL circuit.
Posted on Sep 01, 2009
Sony tv model KV-HA21M80 is having problem front stand by L.E.D is blinking 4 times and stopping
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Electro help
Jan 14, 2015 | Sony Televison & Video
My led power indicator flashes seven times, when i cut the tv on it cuts back off. How do i fix this problem?
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Hope that helps.
Nov 18, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture
your sony ctv is in sleepmode. so kindly press sleep button at remote control .other wise you swith off tv ( that means remove the mains wire from pluck point) then after 5 minutes switch on it will OK.
Aug 02, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Black screen model kv-27fs200 there is sound just no picture stand by light blinks 4 times the pauses and does it again
4 times standby light blink shows problem in vertical deflection section of TV.
Please check and replace vertical output IC in main board.
Thanks.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Dec 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV SONY KV-HA21M80 BG2T
Thanks for reply and nice to know that you are in Algeria.
You need to pay attention on Screen Volts as wrong G2 (screen volts) can be cause of 4 times blinks as you already replaced vertical out put IC.
You can download service manual of KV-HA21M80 from HERE and it is free. Download all 3 parts of file and use WinRaR to unzip it. You will have complete manual in pdf format.
Good luck.
Dec 19, 2008 | Televison & Video
Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony KV-32FS13 TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega model KV-32FS12
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Jan 28, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-27V42 27" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
