Question about Plumbing
Need to replace the impeller and guidevane on Goulds GT15 irrigation pump. Can't get the impeller off. Need help on how to remove it (ie does it just pull off? does motor have to be pulled off?
    Problem Solver:
  • 19 Answers
Impeller will be threaded on, remove by turning counterclockwise
Posted on May 18, 2010
  • Mathew Caron
    Mathew Caron Oct 21, 2013
    how do you hold the shaft still to do that?
How do i remove impeller
Once you take off the front cover. You will see the impeller. Take of the rear cover and the shaft has a flat spot on it. You can hold it with a open ended wrench and spin off the impeller. It will be tight. There is no need to take it off unless it's broken.
Feb 09, 2015 | Goulds Pumps Goulds Pump JRD10 - 1Hp Jrd...
Dissemble pump motor from impeller
The impellers screw on. Hold motor shaft and unscrew.
Oct 08, 2014 | Goulds Pumps Goulds Centrifugal SS Pump &...
HOW can I tell if a Goulds jet pump needs replacement?
pull the foot valve as it takes very little to allow the water to drain back out. Personally I would replace all pipes in the hole with heavy duty /high pressure plastic agricultural irrigation pipes
Aug 17, 2014 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Impeller
J5s is a back pull out. Remove the bolts holding the front casing to the motor. Remove the diffuser. The impeller will either be screwed on. ie the impeller is moulded with a thread, or key wayed .ie a separate metal nut holds down the Noryl impeller and a small piece of "key" steel keeps the impeller on the shaft.
Remove the rear fan cover, and either use a flat screw driver (if there is a slot in the rear of the shaft) or a shifter (if the shaft has a hex) or you may have to prise the fan off. to get a good hold of the shaft.
Hold the rear of the shaft, and with the correct socket undo the hex on the impeller. either the nut or the whole impeller will come off. If just the nut type. Use cable ties to thread down the centre of the impeller to the out side and join. do this in a couple of places.Use these as a lever point to pull off the impeller.
The seal just pulls off. there is two parts stationary and rotating.( 18th may, yourve probably worked it out by now)
May 18, 2013 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Goulds pump
check for air leaks in the connections our your pressure switch is bad
Apr 24, 2013 | Goulds Pumps Goulds GT15 - IRRI-GATOR Self...
I HAVE PROBLEM REMOVING THE IMPELLER ON GOULDS
GOULD ..OH BOY HERE WE GO... YOU MUST HOLD THE SHAFT AT THE BACK OF THE MOTOR WITH A 7/16 TAKE THE CAPACITOR OFF (LOOK AT HOW WIRES ARE ROUTED ) OR 1/2 INCH WRENCH THEN UNSCREW IMPELLER..
>BEST TO BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY OR PUMP REPAIR ,USE YOUR ZIP CODE IN YOUR SEARCH.. DON'T TRY TO REPAIR THIS IF YOU BREAK IT IT WILL COST YOU !
May 20, 2010 | Garden
How do I remove the impeller from a J5S pump?
most pumps arent made to be rebuilt and should just be replaced , its not worth fixing something and have it just go bad again.
Feb 09, 2010 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Plumbing Logo
647 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
