Question about Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas
Rinnai Ductless heaters
The display on our heater has started going dark (dim? out?) for a few hours before returning to the standard brightness. This is reoccurring every few days. The heater is working fine otherwise.
MissKate
  • 1,420 Answers
You may need a new display board. Can you live with it or do you want to spend a few hundred dollars for a new one?
Posted on May 16, 2008
Newly installed rinnai rhfe-1004fa gas heater will not start up
I don't know what's the matter with fixya site it's getting to be a real pain in the as>
Dec 07, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
How do you start the heater?
Water heaters are the part of every home in America. The one of the most common reason of that problem is your lithium battery you have used is outdated. Follow these steps to check the problem.
Closed the valve of gas from back end.
open the water heater cover
Replace lithium battery with new one
Screw in the water heater
Check it
Now it will start
Source:
http://www.rinnai.us/documentation/downloads/Owners_Manual_1004.pdf
http://water-heater-installation.net/problems-and-solution-of-rinnai-tankless-water-heater/
Dec 01, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Need pilot light assembly for Rinnai gas heater model #REH-25-P
Unfortunately, Rinnai only sells repair parts through their authorized dealers. Contact the dealer you purchased it from. If you are not the original owner of the home/heater, you can go to Rinnai's website and search for a dealer near you. http://www.rinnai.us/direct-vent-wall-furnaces/
Feb 28, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai 1004F, no manual. Vent Contol Button is in open position, its winter, should vent be closed at all? Economy button, whats it for?
Not sure about Vent Control however the Economy button is like a night time set back. Over a 2 hour period it will decrease the temperature up to 6 degrees from set point. In morning, just take off economy and unit will come up to temp. Go to www.rinnai.us for on-line manual.
Nov 28, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heater comes on then goes off. Displays code 11 on control panel
Ignition failure. Gas on, flue pipe clear, look inside the stove when you try to start. You should see a arcing which is the iginter.
Tom
Oct 04, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Jul 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai monitor heater 1004F
http://www.rinnai.us/Rinnai.aspx/FileLib
hope this helps
Feb 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Power reset - Rinnai 1004
the rinnai is like a monitor. just unplug it, wait five min and plug it back in. then radjust your temp set point and it should pick back up. when there is a power outage the led-s flash 88:88
Nov 17, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-431FAIII 16,700 BTU Direct Vent Furnace Energy Saver Heater - Natural Gas Logo
50 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
