Question about Sunpak Auto 544 Flash
About parts of Sunpak 544 flashes!
Hi sir,
One easy thing: I would like to buy some transformers (oscillation transformers) of the 544 Sunpak flashes. If you do not know, it's OK, please do not give irrelevant information. Truly said, I am working on those Sunpak flashes in a company and my company has a shortage of these transformers. If you can show me, maybe we will order a lot of them.
Thanks and have nice days.
Tam Bui
  • Tony Parsons
    Tony Parsons Jul 31, 2017
    You may find a source on eBay especially if you can quote the actual reference number. Fixya does not provide or supply parts for any equipment
  • Sunpak Master
  • 16,621 Answers
IF you are working on them then you know the part number on the transformer. You may need to use Alibaba to see if the part is available in China.
Posted on Jul 31, 2017
4 Suggested Answers
kalaci
  • 30 Answers
SOURCE: Sunpak 522 and 544 always firing full power
The probable cause of such behavior is a faulty quench capacitor. The part is specially manufactured to withstand rather high voltage (350 V) and large current peaks (300 A) - despite of its small dimensions - and often goes wrong. Replace it with a capacitor cannibalized from a cheap second-hand shoe-mount flash having the same feature (series thyristor circuitry) and as high guide number as available. Both Sunpak units are highly populated inside, only try to repair them if you have a certain skills in such a job. If any of these explanations is unfamiliar for you then leave the flash alone and take it to a repair shop - there is lethal voltage inside, even long after the unit has been switched off. Good luck! Laszlo (kalaci at index dot hu)
Posted on Jan 24, 2008
kalaci
  • 30 Answers
SOURCE: sunpack 544 flash
There can be more than one reasons for that.
1. Broken wire at sync terminal.
2. Electronic sync issue:
2.1. Faulty sync thyristor (CR02).
2.2. Faulty trigger transformer
2.3. Any other passive component around the previous two.
3. Broken sync lead to the flash tube.
4. Broken leads to the main terminals of the flash tube.
5. Electronic fault at main thyristor.
5.1.Faulty main thyristor.
6. Faulty flash tube.
7. Other, like crack on the PCB.
Good luck! :)
If you happen to decide to part with your faulty flash, please consider to write me first, I offer it a good home... best regards, Laszlo klaci(at)index(dot)hu
Posted on Nov 14, 2008
kalaci
  • 30 Answers
SOURCE: canon I use the Canon XTi and sunpak 544
The Rebel XTi has a sophisticated communication protocol between the camera and a dedicated flash. Only ETTL-II capable flashes can benefit from all the features the engineers at Canon thougt out. This means that with the otherwise superb Sunpak you won't be able to emit autofocus assist pulses, red-eye reduction pulses, the camera won't increase or reduce the flash intensity for bracketing, zoom lens settings won't be reflecting on the flash illumination angle, and so on. But! Set your Canon to full manual (125th sec), set Sunpak to auto, take one of the working apertures according to your taste (depth of field, etc.) and set the same aperture on the camera, and shoot. You still can use bounce flash. I am not sure about second curtain flash, I suspect it won't be possible. Both tele kit and milky filter in front of the flash head are of great help, you don't need to worry about the differences these make in flash intensity. Always keep in mind that the flash makes good exposure according to the given working aperture and, as long as you set the same aperture on the camera, the subject will be correctly illuminated. (I have a Sunpak 522 and a 455 and employ them this way, with success, on my XSi.) Of course you can set set the flash in full manual (M/PR/MD), using the left side, set knob and calculator dial, and this is the only way if you want to make series of shots, because the flash can only make bursts if the power is reduced to at least 1/16th. Good light, Laszlo
Posted on Dec 06, 2008
I have a Sunpack 544, but am missing the flash synchro cord 5' catalog #651-782, Where can I get one?
Paramount manufactures every kind of sync cords for virtually any camera and flash: paramountcords.com
Mar 15, 2014 | Sunpak Auto 544 Flash
Will a sunpak 544 aoto flash work with a nikon D3000? dont see a way to connect the two
The 544 connects to a camera via the PC cord (in this case "PC" has nothing to do with personal computers). The D3000 doesn't have a PC port, so you have to use something like the AS-15. The AS-15 mounts onto the hot shoe on top of the camera and provides a PC port.
Mar 08, 2013 | Sunpak Auto 544 Flash
How can i hook my sunpak 544 to my rebel xti without a slave unit reacting from my internal flash?i see no sync plugs to use on the unit. do they make an adapter or something?
All photo shops hold "hotshoe to PC" adapters for a few bucks. This solves your problem, supposed you have the hosehold-to-PC cable that comes with the 544 as accessory. If not, such cable can be obtained at better photo shops or from www.paramountcords.com. You must know that the flash can be used together with your camera only in Aperture Priority or Manual mode (flash set to auto), or as a fill flash (flash set to Power Ratio mode). The 544 has safe sync voltage.
Oct 12, 2009 | Sunpak Auto 544 Flash
Canon I use the Canon XTi and sunpak 544
Dec 06, 2008 | Sunpak Auto 544 Flash
Flash works intermittantly
There can be more than one causes.
If intermittent work mean that in, at least, some cases the strobe fires normally and the internal sensor controls the power as it should, then the most probable cause is a diry contact at the either end of the PC cord or a broken wire in the cord. Clean with any gentle method or disconnect-reconnect a dozen times in order to rub off the oxidization, or replace in the latter case.
If it doesn't help then the culprit can be a cold solder joint inside the flash, the repair of which asks for a technician with skills.
If the intermittent work means that the flash always fires, but sometimes with the correct power and sometimes with full power, then the case is more sophisticated, and surely needs a repair of internal circuitry. See the description of such issue for a Sunpak 522 elsewhere in Fixya
Good luck, Laszlo
Nov 16, 2008 | Sunpak Auto 544 Flash
Sunpack 544 flash
Good luck! :)
Mar 21, 2008 | Sunpak Auto 544 Flash
Try cleaning that front flash sensor.
Alexander
atdlee@netzero.com
Dec 13, 2007 | Sunpak Auto 544 Flash
Sunpak Auto 544 Flash Logo
102 people viewed this question
Top Sunpak Cameras Experts
bhargav
Doberman
Are you a Sunpak Camera Expert? Answer questions, earn points and help others
