Question about Yamaha P4500 Power Amplifier 2-Channel
Can this present amp use microphone? because i need the one with mic input for my project
    Problem Solver:
  • 5 Answers
This amp require a mixer or a pre amp for the input signal.
No you cannot just plug a microphone into this amp.
Posted on Jul 07, 2010
    Champion:
  • 211 Answers
No, you have to use a mixer or a microphone pre-amplifier.
The inputlevel of those amps are to low for a microphone.
regards,
Gerard
Posted on May 07, 2010
How do I connect a microphone to the system
Unless there is a mic input on the system you can't just connect a mic. You need a pre amp and an amp for the mic.
You could get a mic amp then get a mixer to combine whatever you're playing and the mic.
Apr 30, 2015 | Audio Players & Recorders
Pro 70 lavalier mic- is there away to hook the pro 70 lavlier directly to your computer or mic WITHOUT a mixer or amplifier?
On microphone input of your soundcard if it is not there then sorry you need a tiny amp as the other inputs are all at line level
Jan 22, 2014 | AUDIO-TECHNICA U.S. INC. PRO 70 Cardioid...
How to connect my microphone to toshiba cassette recorder?
Through the mic input.
If it doesn't have one you need a mic pre-amp or a mic mixer.
Mar 23, 2013 | Audio Players & Recorders
No sound
The SM58 needs to be connected to a mic input. A guitar amp is expecting a much louder signal then what a mic can put out.
Dec 31, 2011 | Shure SM58 Professional Microphone
Does the Behringer xm8500 work on it's own, or do I have to hook it up to something? My daughter wants a microphone she can sing into.
All microphones have to be hooked to an amplifier to work. The socket at the bottom with the 3 pins in it is called an XLR jack. You need to plug an XLR cord into that and then plug it into an amp that has an XLR or 1/4 inch microphone input (using an adapter).
If she just wants it for looks, then no, you don't need to plug it in.
Jul 03, 2011 | Behringer XM8500 Professional Microphone
How to make my co3 mic work
You will need a pre amp that supplies whats called phantom power which is power that feeds the mic .. This will come from either mixers [small cheap ones..but check it has XLR mic input with phantom power] or from a stand alone pre amp or audio interfaces with built in inputs for mics with phantom power.. Also you will need an XLR mic lead..Buy a good one with neutrik plugs or similar..
Mar 19, 2010 | Samson CO3 Microphone
I buy a microphone, and I don't now where I have to plug it in, I's called i Carly Microphone, do I need something extra to use it, im trying to plug it in an guitar amplifier...
does it have a cable for it? it should. if it does then just plug it into the amp input jack. there is probably an on/off switch on the mic. i dont know if this is a fixed mic cable or if it is XLR type input on the mic. If there is a place for a cable to plug into the mic at the base of the handle, see if there are 3 pins in the jack of the mic. if so it is XLR, and the amp is 1/4inch so you would need a cable with XLR to 1/4"male. I would go with no shorter than 12 feet, but try to go with 20 to have enough room to move around. Hope that helps.
Nov 04, 2009 | Nickelodeon 684-1220B Microphone
Mono
Hello sir/maam, most (almost all) mic are mono, and the microphone mixer circuit splits the signal to two channel left and right, and fed to two amplifiers, then to two speakers. IF by any chance only mono, we need to trace the path where the mic signal is fed, and where the signal dissappeared, check also your balance control.
If your mic mixer circuit is designed for one channel, contact your local tech to check out or make connection to both channel.
Oct 05, 2009 | Samson R21S Microphone
Trying to use a microphone but not sure how to hook it up
No because the mic is a signel in device and the headphone jack is a signal out jack! meaning if you plug the mic into it the mic will act as a speaker and music will come out of it and ruin it!
I would buy an adapter at radio shack and plug it into the phono input on the back of unit! and if you dont have a phono input you will need to buy a small pre-amp and plug it into the aux or tape input!
That will work!
Please rate my answer!
Thank You!
Jan 16, 2009 | Samson R21S Microphone
Yamaha P4500 Power Amplifier 2-Channel Logo
73 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
