Question about Shure PG48 Consumer Microphone
Vocals Way Too Low, Please Help
I have this microphone connected to my computer via the Lightsnake USB to XLR Cable. I was recording vocals with this mic perfectly fine just an hour ago, then all of a sudden it got very low, whenever I would try to record sound it would barely show up and you could barely hear it. I made sure the mic was plugged in properly, it was turned on, and the settings were set properly. I know this isn't the cables fault because I tested the cable out with another microphone and it worked perfectly. I need this mic for recording vocals and I have really been stressing over this. Please Help
  • Gridlocked Mar 29, 2008
    no help?
    Thanks guys
  • 56 Answers
PG48 has a problem with the on/off switch,it says off even if its set to on.I don't know what do you doing but SM58 is much better
Posted on Jun 10, 2008
Using a Tascam US 122 with Cubase SX, when recording vocals red light (clipping) on the Tascam and in the Cubase mixer, I need to know how to set levels on Tascam, so there will be no clipping on vocal...
Make sure the switch is set to "mic/line" and not "guitar"
Your input level will be set by the "input L" or "input R" knob, depending on which side you are using. Start with them all the way down and then sing into the mic, turning them up until you get a signal about halfway up the bar in Cubase. That should give you plenty of headroom for clean vocals.
It may be difficult to get a good sound if you have one of those cheap mics that has a "1/4" jack instead of a 3-pin XLR jack. You might want to go to your local music/pro audio store and invest in a "condenser" microphone, which is good for vocals in the studio.
Feb 26, 2011 | Tascam US122 Audio/MIDI Interface with...
I'm thinking of buying this microphone for recording vocals to a computer to produce a song, does it connect to a computer through the microphone jack?
No, it does not. A professional mic will not plug directly into a computer. A USB interface, such as the Shure X2u, would be needed.
Nov 21, 2010 | Shure C606 Consumer Microphone
I have problem with my samson g track mic. When I record my vocals I can hear backround noise on my vocals. and I dunno how to get of that 100% I need clear voice not noise on my vocals :((
The Samson G Track microphone is very sensitive. If you have it on the heavy metal base on your computer desk it will pick up the vibrations of computer fans. It's vital to get the microphone off the desk using a mike stand with a boom or invest in the G Track spider holder if you want to use the desktop stand.
You can do a test just by holding the microphone with your hand. You should get very little noise apart from the fan noise with will be very faint. That noise is much easier to remove than the vibration noise as removing the vibration noise affects how your voice sounds.
Hope this helps.
Jan 25, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
Recorded acoustic guitar is fuzzy and distorted
Try anouther Microphone sounds like the frequence sprecturm is to low.
Jul 09, 2009 | Samson C01U USB Condenser Microphone...
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Cannot record
Im having the same probz, got a Hp Pavilion Vista using mobile pre amp usb when i record using a condenser mic XLR nothing is picked up from the channels in Cubase or Nuendo. Im trying to record vocals but the Mic is not picked up and i cannot hear myself in the headphones and it wont transfere to cubase.
It has worked before when i had a desktop, but this only worked with a separate m-audio sound card inside the desktop and i plug in the output jax leads from the desktop (soundcard) to the m-audio usb pre amp
Is this why it is not working for the laptop do i need a Jax connection and where is this audacity
Sep 15, 2008 | M-Audio M AUDIO MOBILE PRE - USB MIC...
SE2200A "wind" noises during recording
Its very descriptive and is quite a common problem with less expensive condenser mics. It's due to dirt or contamination on the capsule insulator or front end circuitry of the electronics. SE should be able to fix it for not much money.
Aug 26, 2008 | SE Electronics SE2200A Professional...
Cant record vocals while listening to beat without the beat being recorded twice
i have the same probelm as da 1st guy,, when i record my vocals some how da beat sneaks into da mic too and fuccs it up.. seriously its ****
Jun 23, 2008 | Alesis Multimix 8 USB 8-Channel Mixer...
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
M-udio usb microphone
You should be able to plug your headphones into your computer and get sound that way, assuming your USB mic is plugged in. If the mic is a USB - direct mic (that is, if it is a microphone with a USB cable directly attached), you will only be able to use it with your PC or laptop. If the device is a mic pre-amp (with an XLR or 1/4" connector that your mic PLUGS INTO), then you should be able to use your microphone with any device that will accept that connection type.
Nov 15, 2007 | M-Audio M AUDIO MOBILE PRE - USB MIC...
Shure PG48 Consumer Microphone Logo
222 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
