Question about GE Profile JTP18 Electric Single Oven
My ge electric stove "drop in, was wired incorrectly, and heard breaker pop. fixed the wiring, and burners work but the front touch screen panel doesn't work now, is there a breaker/fuse on the stove, or how do i fix the elec panel on front of stove, there is no power control at the touch screen. thanks. Steve 704 575-3123
  • steve hirsch May 07, 2010
    so where do you recommend i
    buy a new board the cheapest place?
    should not be hard to replace the board
    myself. I only paid 80 for the stove
    and its 4 years old.
    President:
  • 1,851 Answers
Steve my friend - you have fried the board. There are no breaker or fuse beyond the power point of the stove on your unit.
Posted on May 07, 2010
  • Gary Rice
    Gary Rice May 07, 2010
    WOW - you got lucky as they cost nearly 1000 many places -
    as for replacement parts - they aren't cheap but they are at least available HERE
Half of the element of my range stopped working. How to diagnose or fix a short-circuit?
OK 1 D/C the power to stove. 2 get an olms meter and remove the burners, 3 Put one test wire on the wire to elements wiring other end to plug. . turn on burner switch and see if you get 0 ohms reading if so good cercert. if not bad. move the test lead to each of the 3 plug prongs. before you move to the next wire to the element./ You trace them all you will find your short. also inspect all wire for brakes that could be touching metal. Hope this helps mike
Nov 19, 2014 | Kenmore 47702 / 47704 / 47709 Electric...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When I had two of the stove top burners on and I heard a loud pop. Now nothing works. The oven or stove. What should I do?
sounds like a wire may have shorted. This will trip the breaker or fuse, which ever you have. It will possibly burn the wire in 2. Need to check for separated/ burnt wire.
Jan 19, 2010 | Ovens
Stove burners don't get hot enough and the oven takes a long time to preheat
sounds like its wired incorrectly .. the stove operates on two phases of 120 volts each .. together they form a 240 volt supply .. if its wired incorrectly you may be getting only 120 volts .. it will then take 4 times as long to heat .. have an electrician or someone skilled in that sort of thing, check the voltage at the plug .. and make sure the pig tail is attached correctly to the stove .. check the circuit breakers .. there is one for each phase .. but if one is tripped then some functions wont work at all unless there is a second problem (shorted phase) in which case it will work but have the 4 times as long to heat problem and it will trip the circuit breaker immediatly .. ..
Oct 01, 2009 | Frigidaire Ovens
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
My question concerns a Kenmore glasstop electric oven (model #790.95200100). While operating the oven at 450 degrees and the back right burner at level 5, I heard an audible "pop" and saw a flash of light...
After letting the stove cool, I pulled the entire unit out from the wall and discovered scorch marks on the wall. Opening the back panel revealed a simple fix: the "element on" light module had shorted and was visibly scorched and melted. Looks like a simple replacement (and some wire stripping where the leads fused). Stove currently works with the affected wires capped off (while I await a replacement module).
Sep 14, 2009 | Kenmore Ovens
My GE electric burner is not working.
The know that controls the burner is bad. Take off the front cover and replace the control knob. Be sure you unplug the stove. Let me know how it goes. ken
ps write down the wiring of the control there are 5 wires going to switch there will be little letters on the switch like l1 l2 P com on writing like that.
Dec 22, 2008 | GE JRS04 Electric Single Oven
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
Jun 28, 2008 | Frigidaire FGB24S5A Gas Single Oven
GE JCB909 Range - Blank display
suspect wrongly wired from new
Jun 25, 2008 | GE Ovens
GE Profile JTP18 Electric Single Oven Logo
52 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
