Question about Sharp Office Equipment & Supplies
How to install sharp xerox machine developer - Sharp Office Equipment & Supplies
  • 328 Answers
Tell me name and model of your machine
Posted on Jun 01, 2010
2 Suggested Answers
xptareq2000
  • 1447 Answers
SOURCE: My sharp xerox machine ar5516 is bleaking a man
Man mean maintenance signal.
Reset : # - Interrupt - C -interrupt press 14 press start key.
If you are not fix try next way.
# - Interrupt - C -interrupt press 16 press start key.
Posted on Jan 27, 2010
How to fix the sharp MX-3100N printer? the message on the screen is install the developer.
Developer unit is not detected , or developer is depleted ( which is very bad , because it could mean that it spilled inside your copier , it is very abrasive)
try removing and re-installing the developer unit , and maybe try using another unit for control,
could also be your harness, see if plug of developer unit is plugged into mainbord
Feb 23, 2015 | SHARP MX-3100N
Ar5516 developer spilling out
hi 1 might be developer is very poor quality (generic) 2 check biasing in sharp normally it,s developer issuer and also in this model if u turn mag roller while replacing or just turn and re install in your machine will spill developer
Feb 24, 2014 | Sharp AR-M205 Copier
Sharp photocpi machine ar5520d devloperisdamage after 4 days
The developer was improperly installed. Please install developer type sharp ar205dv.
Jan 20, 2013 | Sharp AR-5520N
Xerox workcenter7346 has fault code 009-390
009-390= IBT belt home position sensor/patch. After examing ibt belt assembly and cleaning patch and sesor, noticed that the magenta developer unit was not in proper position, this was not allowing the ibt unit to turn. Re-positioned developer unit into proper position, installed ibt unit, this cleared up the problem and machine is running fine.
Dec 11, 2012 | Xerox WorkCentreR Pro 7346 Black Toner...
My sharp xerox machine AR-5516 is bleaking a man near toner signal point. why is this bleking? Kindly solve my problem.
The blinking man who we refer to as Mr Bill is a "time for maintenance light". Just ignore it, the machine will keep working.
Aug 21, 2011 | Sharp AR-5320 Black and White Copier
Jan 27, 2010 | Sharp AR-5320 Black and White Copier
Hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Oct 29, 2009 | Xerox Phaser 7750DN Laser Printer
We have the Xerox WorkCentre 665 and it's printing so light.
You can pull the developer houseing out. Wipe the mag roll, so it has a shinny area.
in a small area. Enter the developer housing in again.
Try running a copy.
Remove the developer housing and see if the mag roll moved. If it did not and it is still shinny and clean, this is the problem with light copies. Possibley bad developer housing or ciruit boards. Both are costly.
One other area is, if the developer housing is working, see what brand of toner you are using on this machine?
If it is a brand other than Xerox, dump it all out.
The developer housing has to be completely emptied.
Enter the Xerox toner and see how it works.
Also, a bad Transfer corotron can cause this problem, it may be arching in the blocks.
If all else fails, call Xerox for this major repair.
Feb 23, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
Xerox WorkCentre XL2120 Vista Compatable Driver
Here is the answer from Xerox
Windows Vista Note: There are no plans to develop Vista drivers for the Xerox Small Office/Home Office products. Please check with a Xerox Sales Representative for the latest products with Vista support.
Nov 30, 2007 | Xerox WorkCentre XL2120 Laser Printer
64 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
